Aspire PSU with bad caps
  • Rulycat
    • Apr 2010
    • 724
    Re: Aspire PSU with bad caps
    Aren't you just wasting money on electricity bills through using such an inefficient POS though?
    • BigTroll
      • Sep 2010
      • 1317
      • LAMBDA SOND
      Good point luckily our electricity bill is subsidized so its only like $50 a month.
      My Computer: AMD Ryzen 9 3900X, Asrock X370 Killer SLI/AC, 32GB G.SKILL TRIDENT Z RGB DDR4 3200, 500GB WD Black NVME and 2TB Toshiba HD,Geforce RTX 3080 FOUNDERS Edition, In-Win 303 White, EVGA SuperNova 750 G3, Windows 10 Pro
      • Rulycat
        • Apr 2010
        • 724
        Unfortunately they are anything but subsidised here. Efficiency is worth its weight in gold!
        • BigTroll
          • Sep 2010
          • 1317
          • LAMBDA SOND
          yeah well my main rig has that pc power and cooling supply its pretty efficient with active pfc.
            UGH! Sorry, I hate when people say active PFC is more efficient.
            It isn't! If anything it makes it LESS efficient. It's like adding 5-10% of losses. It's not a free lunch by any means. All it does is shape the input current to give the power supply a high power factor. You as an electrical supplier's customer do not pay a penny more if your PSU uses power at 0.5 PF or 0.99 PF.
            The only reason it is used is a) it makes a PSU cheaper for high output power (smaller main capacitors and relaxed primary design) and b) it's a legal requirement in the EU above about 75W (though you can get away with passive PFC up to 200W.)
            • BigTroll
              • Sep 2010
              • 1317
              • LAMBDA SOND
              #26
              Thats quite interested I never knew that, I really appreciate that I will use it to TROLL my co-workers tomorrow.
              • Behemot
                • 4845
                • CZ
                #27
                Active is not that much like 5-10 % I think. Quite interesting is ppl still talk about PFC only, but they do not consider loses in the network (when higher current flows before and after the PSU, there are always loses). Not mentioning the necesity of higher-dimensed brakers and so on.
                  Typical PFC boost stage efficiency is 88-95%, so 5-12% losses.
                  - https://cdn.badcaps-static.com/pdfs/...389b97635a.pdf (page 11)
                  Typical losses in the UK distribution network are less than 2%, and that's for hundreds of km of wire. Your home typically has about 1-2 ohms of resistance in the cabling, which makes hardly any difference (if you've got an 500VA reactive load, it's about 9W of losses, or 1.8%.)
                  Don't know about your house, but we have (at home) 32A breakers on the upper and lower sockets. The computer uses less than an amp typically, but the washing machine and tumble drier use about 15A total. Which matters most to the breaker?
                  PFC is good for the electric company, but costs the consumer more.
                  • Behemot
                    • 4845
                    • CZ
                    #29
                    To the braker matters everything. Typically in average house/flat ppl have at least 1 PC, 1 display, 1 TV, 1 satellite reciever/set-top box running. Than you turn on oven and cooker and when you also want to turn on electric kettle (is there some word for that? ), suddenly breaker goes off. Oh whatafuk? Is it those SMPS-build electronic appliances take 3-5 extra amperes more than it could just because they have no/passive PFC?
                    I guess you use superconductors than, our distrubiton losses are arround 10 % (that is only oficial statement I found in some electricity usage overview, but it is many years old number).
                    I am sorry, but I do not believe that PFC efficiency numbers. Or more specifically, I do not believe the number is so big in computer PSU PFC circuits. Half of the better todays PSUs on consumer market has efficiency of 85-90 % total. So if the PFC had your 88-95 % efficiency than it would mean from 66 % up to 100 % wasted power is wasted by the PFC only! This is not true obviously.
                    Our major electric producer is state-owned company so we indirectly pay new power stations anyway. So I rather see lower wasted power (cause power station-wise, reactive load is wasted power). Sorry, but it's your problem you privatised your energetic companies (or never had any, don't know), it is one of the things which should belong to state under every circuimstances.
                    • mariushm
                      • May 2011
                      • 3799
                      #30
                      Power factor correction is indeed something more beneficial to power companies, as the power company loses money due to losses in electrical network due to low power factor.
                      However, there are also some benefits due to the higher voltage the power supplies have when using Active PFC.. lower losses in the transformer and inductors among other things.
                      So the minor loss due to pfc boost circuitry is often offset by the benefits.
                      There's a couple of videos which explain nicely the power factor in a surprising way, by explaining what impedance is:
                      http://www.youtube.com/watch?v=xyMH8wKK-Ag
                      http://www.youtube.com/watch?v=tZBMfDvWF4U
                      I quite enjoyed learning about impedance from these, and the power factor discussion was the cherry on the cake.
                        Hmm, I have never tripped a breaker myself when using normal loads. Trip curves - you can draw about 64A from a 32A breaker (type C) for about 2 minutes IIRC... and 32A for around 2 hours. If you breaker is tripping too early, it needs to be changed.
                        PFC can be efficient, but the point is it contributes only losses to the customer. It can be beneficial for the power company. Which MAY be beneficial for the consumer, but there are a lot of non-PFC loads still out there, and as I said, there's not much lost, so it just leads to greater usage.
                        Reactive loads aren't lost to the power company. They just cost more to transmit. But it's not like 500VA with 250W real power costs twice as much to generate, it's maybe a couple of percent (with cut-throat margins, it can mean a lot to the power company.)
                        The 2% statistic came from a science textbook. I'll try and get a source.
                          ACER Aspire Aspire X3910 Aspire E5700 Specification for Upgrade or Repair
                          This specification for the ACER Aspire Aspire X3910 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire X3910 boardview and Aspire Aspire X3910 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                          09-12-2024, 03:36 PM
                          ACER Aspire Aspire XC-886 Aspire XC i5-9400 Specification for Upgrade or Repair
                          This specification for the ACER Aspire Aspire XC-886 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire XC-886 boardview and Aspire Aspire XC-886 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                          09-12-2024, 03:30 PM
                          ACER Aspire Aspire XC-330 Aspire XC A4-9120e Specification for Upgrade or Repair
                          This specification for the ACER Aspire Aspire XC-330 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire XC-330 boardview and Aspire Aspire XC-330 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                          ACER Aspire Aspire TC-886 Aspire TC i7-9700 Specification for Upgrade or Repair
                          This specification for the ACER Aspire Aspire TC-886 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire TC-886 boardview and Aspire Aspire TC-886 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                          09-12-2024, 03:28 PM
                          ACER Aspire Aspire TC-885 Aspire TC i7-8700 Specification for Upgrade or Repair
                          This specification for the ACER Aspire Aspire TC-885 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire TC-885 boardview and Aspire Aspire TC-885 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
