Panasonic Viera TC-P50G10 7 Blinking Red question
  • landyboy
    • Apr 2013
    • 443
    Following the technical manual I have done the SC, SU, SD isolation. Set has 7 blinks with everything connected as normal. When I isolate the SU per the manual I still get 7 blinks. When I isolate the SD there are no longer any blinks just a solid red light. Do you agree this would indicate a bad SD card?
  • landyboy
    • Apr 2013
    • 443
    Re: Panasonic Viera TC-P50G10 7 Blinking Red question
    http://tsn.pstc.panasonic.com/PASS/o...ical_Guide.pdf
    Slides 64 and 65
      This belongs in TV forum.
      With SD pulled & SC50 jumpered, does upper half of panel glow (or even better show an image?)
      • landyboy
        • Apr 2013
        • 443
        Tom, My fault I wasn't paying attention when I posted it. And no there was nothing on the panel at all.
          Just a green or red solid LED, fans running?
          • landyboy
            • Apr 2013
            • 443
            Solid Red no fans.
              The fans should spin if no problem occurred. Also, you should be able to get TV sound. You may have A board problem causing 7 blink fault.
              • Andre Gilbert
                by Andre Gilbert
                11-20-2024, 08:52 PM
              • jm1234
                Panasonic plasma TX-P42ST50 - 6 blinks
                by jm1234
                anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                I checked that board for any obvious faults...
                05-22-2024, 06:59 AM
              • riparo
                Panasonic Oled 55EZ950E, no picture, red led blinking every 4 sec
                by riparo
                Hi everyone, I have a Panasonic OLED TV model 55EZ950E, as soon as I turn it on I don't have any image the LED goes from green to red LED blinking every 4 sec, I found the service manual suggests checking OLED PANEL, PB BOARD, T-CON connectors but it seems like everything ok, I didn't find any burns under the pb board
                I attach a link to download the service manual, thank you for anyone who can help me
                https://tel-spb.ru/download/?brand=P...0E_LA73.rar​
                01-11-2024, 12:35 PM
              • Alicat
                Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
                by Alicat
                Stopped by this site trying to fix my parents Panasonic Plasma TV.
                Model number is TH-50PZ85U
                Power comes on and the red power light stays on solid.
                Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
                I also hear a few clicks.
                I also think my parents said there was a thunderstorm and the TV failed after that.
                Section 6 in the service manual talks about power and no screen,...
                10-30-2024, 10:09 AM
              • mmischni
                Panasonic Viera Plasma TH-42PX75U 7 Blinks/8 Blinks/burned P board?
                by mmischni
                Greetings friends,
                I have a Panasonic TH-42PX75U manufactured in 2007. It has been trouble-free until recently. One evening I turned it on and it then powered back off and gave 7 blinks.
                First a question about the blinks. Everyone only speaks of a single number of blinks. I noticed on my TV, it blinks one fewer times for the first group of blinks, then blinks the full number repeatedly. So for my first code in question, the TV switches off, blinks 6, then blinks 7 repeatedly. When I disconnected the SC board, the TV switches off, blinks 7, then blinks 8 repeatedly....
                09-06-2017, 08:52 PM
