19v adapter to 16v?
  • spleenharvester
    • Mar 2010
    • 902
    Re: 19v adapter to 16v?
    Also, for anyone reading, just fired up a +16v IBM X31 with a +19V adapter. So clearly not much of a problem!
    Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSD
      • Jul 2011
      • 6040
      Originally posted by ben7
      Look for a part that has "431" written on it. These are commonly used in smps feedback circuits. They are adjustable voltage shunts. The voltage is set by two external resistors. To change the output voltage, you simply change the resistors to the right values.
      What is the part # so I can find a data sheet thanks
      • mariushm
        • May 2011
        • 3799
        It's TL431 ... a "jellybean" component, thousands of versions from lots of manufacturers.
        http://www.digikey.com/product-searc...keywords=tl431
        • ben7
          Capaholic
          • Jan 2011
          • 4059
          Yeah, it is also commonly called the 'KA431' or the 'LM431'.
          Muh-soggy-knee
            "TL" stands for Texas (Instruments) Linear
            "LM" stands for Linear Monolithic
            The first two characters are usually manufacturer specific.
            • ben7
              Capaholic
              • Jan 2011
              • 4059
              I think 'KA' is used on the Fairchild made 431's...
              Muh-soggy-knee
              • Behemot
                • 4845
                • CZ
                #27
                And KIA431 is for KIA obviously
                  • Jul 2011
                  • 6040
                  Thanks for the info
                  • kapurk
                    • Aug 2013
                    • India
                    #29
                    ben7 has the right answer. Almost all Laptop adapters use a TL431 or similar voltage regulator which uses 2 resistors as a voltage divider to sense the output voltage. see the attached pdf file. R13 and R14 are the two resistors. The values of the 2 resistors are not critical; what is important is the ratio. The ratio should be such that for the required output the voltage at pin 1 of TL431 is 2.5. The formula for calculating R13 and R14 is as follows:
                    R13 = R14(V-2.5)/2.5 where V is the required output voltage
                    If you fix the output as 16V, then it simplifies to:
                    R13 = R14 *13.5/2.5 OR
                    R13 = R14 * 5.4
                    So if R13 is 10k then you need 54k for R13.
                    you can try different values for R14 to get an easily available value for both so long as R13 stays in the range 10k to 15k. Or better still replace both with a 100k preset and use it to set the output to any voltage you want!
                    • mariushm
                      • May 2011
                      • 3799
                      #30
                      TL431 is used as a voltage reference, not as a voltage regulator... it can be adjusted to output a certain voltage based on the resistors used.
                      Then, it depends, a classic method is to use an operational amplifier or a comparator to compare the output voltage with the voltage reference and adjust the pwm frequency accordingly, to raise or reduce the output voltage.
                      All that resistor math is pointless, there's no unique formula, each power supply can be different (give it a different input voltage, adjust the reference for a particular output voltage etc). It's enough to read the datasheet of such a *431 IC to understand how it works.
                      • kapurk
                        • Aug 2013
                        • India
                        #31
                        Whoa man! Yes, I agree that the TL431 is a voltage reference not a regulator - that was a slip. However, that resistor math will work with almost all adapters that use the TL431 in this configuration. I hope you saw the attached PDF file. Just to let you know, I am a manufacturer of laptop adapters. Almost all adapters these days use a very similar output circuit design with a TL431 or similar voltage reference for output voltage control. The PWM part of the circuit, does have a lot of variations but the overall design concept is still common.
                        I noticed someone mentioning an undervoltage cutoff coming into play. That is a possibility. Tweaking the voltage dividers may not work beyond a stage because the PWM circuit may become unstable or stop working altogether.
