Ultra X4 600 ULT-HE620X repair project
  • LDSisHere
    • May 2012
    • 727
    • U.S.A.
    I am attempting to repair this Ultra X4 supply but I am not sure what my best option is on replacing a couple of surface mount transistors and I am hoping I can get some helpful input from the forum.
    I think I have identified them, but of course I am not 100% certain. One I can easily find a replacement, the other one is not in stock at Digi-Key so I am not sure what part of its' specs are the most important when trying to source a replacement.
    These two transistors are the only ones on this supply with these particular markings and of course they are not complete due to the transistors being blown. Q10, I believe is marked ZC which I think is a MMBT4124. The MMBT4124 is the transistor in stock at Digi-Key. Q8 appears to be marked ZD which I think is a KST4125. Digi-Key does not stock this transistor and it is the one for which I need to find a suitable replacement. I could be completely wrong on both identifications and if anyone has a better idea on what they really are I would appreciate the input.
    These transistors are connected to the CM6068A PWM pin. The CM6068A controls both the APFC and the primary side PWM functions. It appears that these transistors act as the driver between the chip and the main FETS.
  • LDSisHere
    • May 2012
    • 727
    • U.S.A.
    Re: Ultra X4 600 ULT-HE620X repair project
    I have decided to replace Q10 with a MMBT3906 and Q8 with a MMBT3904. These transistors have a higher voltage rating than the original which I think is beneficial. How well they will work remains to be seen. I am just hoping I have correctly identified the original transistors in the first place, if not my testing may get very interesting at least for a few seconds. Identifying surface mount components is a real pain in the rear and somewhat of a crap shoot IMO.
    • shovenose
      Send Doge Memes
      • Aug 2010
      • 6575
      The caps in those power supplies suck... hopefully you will replace with quality caps
      • LDSisHere
        • May 2012
        • 727
        • U.S.A.
        The APFC is now working on this supply. The supply still will not turn on and I have not yet bothered to troubleshoot the problem. Hopefully it is only a minor issue, but with my luck it will be something off the wall.
        • everell
          • Jan 2009
          • 1514
          So............what all did you do to get the APFC working again? In my experience if the transistors are blown up, the booster coil is shorted (or intermittently causing problems which will blow up the transistors again).
          Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
          • LDSisHere
            • May 2012
            • 727
            • U.S.A.
            I replaced all the components that I could determine were bad. I do not have any good pictures of the primary side, the one I attached is the best I could find. I will take some better ones when I get a chance. It is possible that the booster coil is damaged however I could not see any indications to support it. Time will tell I suppose if I can eventually get it to turn on.
            • LDSisHere
              • May 2012
              • 727
              • U.S.A.
              I was able to take some pictures last night. Just to make sure I am understanding you correctly, when you say booster coil you are talking about the one the arrow is pointing at in the first attached image, correct?
              • everell
                • Jan 2009
                • 1514
                The same company that sells the Blue ESR Tester sells a Ring Tester. I wasn't sure where I would use it, but I bought one to play with. One thing I found is that using a DVM ohmmeter will not tell you much about a booster coil. Whether good or shorted the resistance is about the same. Putting the ring tester on it gives an immediate indication of short, substandard performance (probably some windings shorted, or a good ring. So....I am glad I bought it, and checking the booster coil with the ring tester is one of the first things I do when troubleshooting APFC circuits. I have already found a few shorted booster coils along with the shorted transistors.
                • everell
                  • Jan 2009
                  • 1514
                  Yes, that is the booster coil. Visually, I could not see any difference between a good coil and a shorted coil. Only the ring tester could verify a problem. Also, temperature is a factor. The hotter the coil runs the more likely a short. Use a temperature gun to try to determine operating temperature. If the mfg. uses a cheap core, the coil will run hotter and cause problems with time.
                  • LDSisHere
                    • May 2012
                    • 727
                    • U.S.A.
                    Is there a way to use a scope to do the same thing as the ring tester? I had considered buying a ring tester before, but I thought I would use a scope more often. My tool/toy buying is high on the wife's radar for now so I am trying to keep it to a minimum for a while.
                    • LDSisHere
                      • May 2012
                      • 727
                      • U.S.A.
                      I think I may have found the reason this supply is not turning on. The "current sense" resistor between the the FET and common was blown. Normally I do not have a problem determining the value of a resistor if I can make out the color bands but this one is confusing me so I am hoping for some input as to its' value.
                      It looks to me like the the colors are:
                      Green - Gold - Silver - Grey - Brown
                      or
                      Brown - Grey - Silver - Gold - Green
                      Either way these colors in these orders do not make any sense so any input would be appreciated.
                      I have also ordered a Blue Ring Tester, I have wanted one for a while so I went for it.
                      • cheapie
                        null
                        • Jul 2010
                        • 849
                        or
                        It's pointing towards a 0.18 ohm +/- 5% resistor (meaning of the 5th band is unknown in this case). That is with the second possible orientation. The first is completely invalid, as the first or second band cannot be silver or gold.
                        • LDSisHere
                          • May 2012
                          • 727
                          • U.S.A.
                          This is what I was thinking myself but I was not sure, the green band was throwing me off.
                          • everell
                            • Jan 2009
                            • 1514
                            I think that green band is either the type of resistor or the manufacturer of the resistor. Some of those low ohm resistors are flame resistant and others are not.
                            • LDSisHere
                              • May 2012
                              • 727
                              • U.S.A.
                              It would have been much better if they had marked it in a different way.
                              I found a replacement for the burnt resistor, but the supply still did not turn on. I then discovered that R42 was open. I replaced R42 with another 430 ohm resistor but still no luck. It looks like more probing and troubleshooting are in my future with this supply.
                              • LDSisHere
                                • May 2012
                                • 727
                                • U.S.A.
                                My ring tester shows that the booster coil is good.
                                I pulled the secondary heat sink to test the diodes. The forward voltage drop is very low, is this normal?
                                STPS60L45CW - 0.095V
                                40 CPQ060 - 0.112V
                                The resistance is about 100 ohms with the leads orientated the same as to check the forward voltage drop. It shows infinite resistance when the leads are reversed.
                                I have attached the datasheet for the two diodes.
                                • ben7
                                  Capaholic
                                  • Jan 2011
                                  • 4059
                                  Sounds like the diode you have is good.
                                  I measured a schottky diode the other day which according to the datasheet, the Vf is 0.6 volts. Well, my DMM says it is around 0.2 volts. I think it has to do with the voltage and current the DMM 's diode test works at.
                                  Muh-soggy-knee
                                  • mockingbird
                                    • Dec 2008
                                    • 5484
                                    AnaTek Ring Tester is around $42 + shipping for the kit...
                                    What do you think about the UNI-T UT602?
                                    $40 shipped from China.
                                    • LDSisHere
                                      • May 2012
                                      • 727
                                      • U.S.A.
                                      Thanks for the second opinion, I have put the diodes / heat sink back on the supply but I have not had a chance to do any more testing.
                                      I am not sure how they would compare as I just received my ring tester on Wednesday and I have not had much of a chance to play with it much. With what little testing I did, I quickly found out it is not good for testing inductors on the secondary side. It does not give a numerical value only a range of LED's to gauge to health of the item being tested.
                                      I like the assemble it yourself, through hole component design of the the ring tester. I like that it matches my Blue ESR tester and I think it will do the job I purchased it to do.
                                      • LDSisHere
                                        • May 2012
                                        • 727
                                        • U.S.A.
                                        I have made some good progress with this supply but I am going to make several small posts about it instead of one big one.
                                        I wanted to start by asking for help in identifying the rating for the part in the attached picture.
                                        I am reading it as 2.5 ohm 6 Amp however that does not seem like it would be correct for this supply. The main fuse was rated at 15 Amps and the APFC diode is rated for 16 Amps so why would this only be rated for 6 Amps if that is in fact the rating? Any useful input on this would be much appreciated.
                                          LG Gram Ultra-Lightweight Notebook Specification for Upgrade or Repair
                                          This specification for the LG Gram Ultra-Lightweight Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-Lightweight boardview and Ultra-Lightweight schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-07-2024, 03:40 AM
                                          LG Gram Ultra-light Weight Notebook Specification for Upgrade or Repair
                                          This specification for the LG Gram Ultra-light Weight Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-light Weight boardview and Ultra-light Weight schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          LG Gram Ultra-Light Laptop Notebook Specification for Upgrade or Repair
                                          This specification for the LG Gram Ultra-Light Laptop Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-Light Laptop boardview and Ultra-Light Laptop schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-06-2024, 09:10 PM
