Description of why a fuse blows
  • johnnydiaz
    • Apr 2012
    • 52
    I have always heard that if a fuse violently blows its due to a mosfet or bridge rectifier. Can someone explain this in detail. Why would the mosfet or bridge rectifier fail and how does the fuse blow up? Sorry for the newbie question.
    Thanks,
    Johnny
  • 370forlife
    Large Marge
    • Aug 2008
    • 3112
    Re: Description of why a fuse blows
    If a fuse blows, it is because something is drawing more power through the fuse than what it is capable of carrying.
    I.E. in a power supply a MOSFET on the primary acting as a primary switcher. For some reason, the MOSFET blows up, shorting itself out. This short tries to pull more current through the fuse than what the fuse is rated for and the metal filament in the fuse gets so hot that it melts itself and cuts the power.
    • twbranch
      Mad Nerd
      • Oct 2012
      • 153
      Wow a pretty good explanation! Now can you explain how a transistor works?...hahaha! Not trying to hijack just some people can't explain it and that was a good explanation of simple component in my opinion!
      • 370forlife
        Large Marge
        • Aug 2008
        • 3112
        http://www.youtube.com/watch?v=-td7YT-Pums
        This is a pretty good video.
        • ben7
          Capaholic
          • Jan 2011
          • 4059
          Basically, the larger the short circuit is, the faster/more violent the fuse will blow, because the immense current heats up the fuse link very fast. Sometimes so fast that the fuse link actually vaporizes in plasma, which expands violently, causing the fuse glass to shatter!
          You can make a fuse link glow by giving it just enough current, not enough to make it melt in two.
          Fuse link - the wire inside the fuse which melts and interrupts the circuit.
          Muh-soggy-knee
          • mariushm
            • May 2011
            • 3799
            I personally have a hard time remaining with some knowledge from those Make videos where that Colin guy appears.
            The videos are somewhat empty in actual information and in a way, I almost can't stand him (he pauses a lot in the videos as if he just said or is about to say something intelligent, it's annoying to me)
            I found these to be better to understand what transistors are (well, the most common transistors) :
            SparkFun According to Pete 7-5-11: Diodes and Transistors
            a very easy to follow explanation of diodes and the common transistors, with simple words :
            http://www.youtube.com/watch?v=w9cd7B5QRRo
            Tutorial: How to design a transistor circuit that controls low-power devices
            http://www.youtube.com/watch?v=8DMZSxS-xVc
            a "hands-on" practical example where the guy explains and does the math to show you how to use a transistor to turn on and off something
            Some more technical videos about the operating modes of a transistor (linear mode, cut-off mode, saturation mode)
            Introduction, explanations : http://www.youtube.com/watch?v=HVECDUeJRw8
            Saturation mode: http://www.youtube.com/watch?v=MSYHjMMgQd4
            Cut-off mode: http://www.youtube.com/watch?v=61sBLBr-_OA
            • tmiha71
              • Apr 2010
              • 130
              Energy needed to blow fuse is for few orders of magnitude lower than energy needed to blow (explode) MOSFET (fuse WILL always blow /explode/ first, compared to MOSFET, will preserve MOSFET )...
              Explosion usually breaks connection, so if MOSFET blows /breaks connection/ fuse can survive dissaster...
              It'll be better to say, "..., the MOSFET did not close, when it had to, current rised,..."
              But, if MOSFET is blown...
              Reasons for blown (exploded) MOSFET are :
              - excessive voltage (above rating)
              - excessive current (above rating)...
              And this (excessive) energy CAN NOT came through fuse (purpose of fuse)...
              If it did not came through fuse, that speaks of some unwanted effects (LC circuit) which are pretty STRONG...
              • Jane
                How do you test MOSFET in laptops ?
                by Jane
                I tried to use this method:
                Testing an N-channel MOSFET:
                Step 1: Discharge the Gate (turn off the MOSFET)
                Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
                Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
                Step 2: Charge the Gate (turn on the MOSFET)
                Now, place the red probe on the Gate (G) and the black probe on the
                09-27-2024, 03:31 AM
              • corrize
                A funny fuse story – Lumix LX100 II
                by corrize
                Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
                I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
                The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
                There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
                And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
                10-19-2023, 09:58 AM
              • Nooy
                VGA MOSfet permanently shorted and loss of MOSfet pad
                by Nooy
                Hello everyone, I recently found this badcaps site and super Learn Electronics Repair youtube channel. And I wanted to learn how to troubleshoot power supplies and VGA cards and how to practice soldering, since I already have a properly defective piece of them. I am currently trying to solve two problems:
                I have a Gigabyte GV-RX460WF2OC-4GD type card. I managed to find the faulty MOSfet (AON6414A) on it, which I replaced. The card starts up, but after about half a minute, the MOSfet in the same position will be shorted again. Is it possible that the PWM controller driving the MOSfet...
                02-14-2024, 02:26 AM
              • Michale32086
                LG 60LN5400 Blows TCON Fuse
                by Michale32086
                I could have sworn I posted about this before, but I can't seem to find the post..
                To whit..
                I have a 60LN5400 that came in.. Backlights work fine.. No display..
                Traced the problem to the TCON board.. Blown fuse..
                Replaced the fuse.. Blows again.. Replaced the fuse again... This time it fries the marked part on the Main Video board...
                Got a new Main Video Board.. Replaced the fuse on the TCON..
                The fuse is fine and the backlights come on fine if I don't have the cellophane connectors from the TCON to the...
                10-30-2019, 09:21 AM
              • redbaron1007
                Help identifying mosfet on Razer Blade RZ09 (CH570_MB_NT)
                by redbaron1007
                I have a Razer laptop (RZ09 MB# CH570_MB_NT) that has a shorted mosfet marked BND M03 E067 that I'm unable to find anywhere online. Does anyone either know what the part number is for this mosfet or have a schematic I can find it in?
                Backstory on the whole thing the laptop was plugged into a lamp at a hotel. The lamp got unplugged while it was charging and now the system won't power on anymore. I found the caps around this mosfet shorted and when I injected voltage into the caps the mosfet got hot and my bench psu was pulling 5A. Pretty sure this is all that's wrong with the laptop...
                09-09-2025, 11:10 AM
