Got this PSU for repair - it stopped working:
Oh, one of the big caps is bulged and leaked - note the electrolyte on the heatsink:
Overall look - only good caps:
Both big caps removed - and dried electrolyte on the PCB:
Two resistors connected in paralle with the caps - they're different! According to the colors, one is 51K and the other one 61K. The 61K one was connected in parallel with the blown cap and both resistor and the cap were open - thus the PSU didn't work at all. Why the resistors weren't the same? A mistake or intention?
Replaced both resistors with 100K ones and installed new caps (only 330uF as I didn't have anything better):
After repair, I was not able to power it up. +5VSB worked but that was all. Then I found out that the PS_ON signal is active high (unlike standard ATX) - must be connected to +5VSB to turn on, not GND. Then it worked fine. It needs some load on the rails and the voltages weren't nice at all - looks like it's a feature as it's designed for specific Compaq system only (the voltages are probably good with that specific load).
