1LG4B10Y04800 capacitor schematic
  • stupidstuff
    • Sep 2012
    • 3
    • new england
    Hey everybody. I'm looking for the schematic for the power/main board 1LG4B10Y04800 I'm not sure if it makes a difference, but it says N7AL on the board but N7EK on the sticker with the bar code on it, from a Sanyo TV model DP46840. I de-soldered all my capacitors to check them but lost my list. I don't know what capacitors go where. Really I only need a list of capacitor places and values. If anyone can help I would REALLY!!!! appreciate it.
  • MORETTIGIAN
    Capacitor detached from PCB – RTX 2070 Super Founders Edition
    by MORETTIGIAN
    Title:
    Description:
    During maintenance on an RTX 2070 SUPER Founders Edition, I found a capacitor lying on my desk after reassembly.
    I did not notice it detaching, so I am unsure of its original location on the PCB.
    Procedure performed:
    - Removed backplate
    - Cleaned heatsink and PCB with isopropyl alcohol + soft ESD brush
    - Reapplied thermal compound
    - Reassembled card
    Observed behavior after reassembly:
    - GPU powers on and operates normally under...
    09-18-2025, 12:14 PM
  • tranquility
    newbie needs capacitor sizes. HP Spectre X360. schematic maybe available
    by tranquility
    hello, i am very new to laptop repair and generell electronics
    i have a HP Spectre X360 Convertible 13 - ap0016ng
    motherboard number DA0X36MBAE0 REV E
    massive burned and shortet mosfets. after removing them still shortet in the i think "main power rail"
    found a shorted capacitor. removed it and the short is gone.
    i want to try a crazy repair which is hard because the mosfets are like welded on one side to the track. is there a method to get this loose ?
    in this area another capacitor was shortet.
    12-06-2024, 04:12 AM
  • Mark D
    Samsung UN65JU67ODFXZA Version TD01 Schematic and Parts List
    by Mark D
    The TV is a Samsung UN65JU67ODFXZA Version TD01. I replaced the power source board and the TV is now working, but I decided to try and troubleshoot the old board to fix at the component level. Trying to get a schematic and a parts list has proven to be an issue. Trying on my own, I can't tell you how many times my Norton security has flagged sites as "malicious". I ordered a service manual from ServiceManuals.net, paid $16.99 and got 66 pages of everything BUT schematics and component parts list! Can anyone steer me in the right direction? Some of the surface mounted component parts...
    10-29-2024, 03:15 PM
  • devsigner
    identify capacitor for MacBook Pro with rare logic board 820-02037-06
    by devsigner
    Hi
    While messing around with my MacBook Pro, I stupidly pinged off a very small surface mounted component that I’m now trying to identify.
    resistance tests show a rising resistance value, indicating a capacitor.
    The laptop boots up and runs, however I'm choosing not to use it until I get it fixed.
    i can’t see any markings on the capacitor at 10x magnification using a professional jewler's loop.
    It seems like there's some damage to the capacitor - one side doesn't have "shiny bits" - can you tell I don't do this for a living!...
    Yesterday, 01:39 PM
  • Agent24
    Dick Smith Q-1760 linear power supply filter capacitor question
    by Agent24
    I have acquired a used Dick Smith Q-1760 power supply - although the OEM is Manson Industrial
    It has at least one problem.
    The voltage control potentiometer VR2, 50K is faulty - going high resistance / open circuit in the CCW end and leading to the output voltage jumping around.
    I have already ordered a replacement potentiometer, so that's not an issue.
    Now, I want to replace all three electrolytics on the PCB as they are CapXon and I don't trust them so much, I will replace them with something better while I've got the thing apart anyway.
    All are CapXon...
    10-21-2025, 05:39 PM
