120W switching power supply designed to run a 280 LED pannel asking a question
    • Jul 2011
    • 6057
    120W switching power supply designed to replace most laptop computer power supplies currently available.
    Voltage adjustable between 15 and 24VDC. 15-20Vdc / 6A max. 20-24Vdc/ 5A max. Also has a 5V USB jack.
    Here is what I want to I want to make this adj-able from 17 volts to 24 volts is there any thing I should watch out for doing this
    Thank You
    Here is the link to where I am going to buy a few of them
    http://www.allelectronics.com/make-a...L-REPLACEMENT/
    1.html
    I have made these in to a adj-able(by removing the selector switch and putting in a small pot) power supply before and one them I fried the 12 volt zener diode and pop a cap because the voltage when to
    30 volts but after I removed the diode and replaced the cap the power supply was working again
    Model# PHC-1000K. Perfect for small appliances and breadboard projects. Provides 3 / 4.5 / 6 / 7.5 / 9 or 12 Vdc, and it's regulated,
    so the voltage doesn't fluctuate when the load varies.
    http://www.allelectronics.com/make-a...-OUTPUT/1.html
  • mariushm
    • May 2011
    • 3799
    Re: 120W switching power supply designed to run a 280 LED pannel asking a question
    PHC-1000K is too expensive. I'm not sure how "regulated" it is, no matter what the description says.
    You can build one yourself for much cheaper and it would be very regulated but it won't look as nice.
    You get a 12v 1.5-2A transformer, use a bridge rectifier to convert to DC and then get a simple linear regulator or a switchng regulator on a heatsink to go down to whatever you want.
    It won't be enough to run those leds.
    The panel leds have 2-3v voltage drop, so it depends how those leds are connected - it looks like they're about 8-9 leds vertically. If that's how those are connected, I can see why the panel would need 18-24v.
    The one in the link looks ok.
      • Jul 2011
      • 6057
      Re: 120W switching power supply designed to run a 280 LED panel asking a question
      PHC-1000K dose regulated fairly well I do agree that it is a little costly but I need a small board to a job
      • 999999999
        • Sep 2006
        • 774
        The LEDs don't appear to be heatsunk very well (just a guess, I can't see the back) so you probably want to run them at no more than 20mA per. They are going to need a lot closer to 3.0V than 2.0V being white LEDs, maybe slightly more than 3.0V but let's call it 3.0V for now...
        280 * .02A * 3V = 16.8W
        $40 for a 120W PSU seems overkill. Mariushm mentioned the issue of how the LEDs are arranged, have you determined they are actually wire as parallel runs of 8 LEDs in each series? If so, you should aim for at least a 26V PSU to give a little margin then limit current to 20mA with a series resistor on each series of LEDs. Trying to adjust the PSU to some exact voltage to cause 20mA or whatever your target current, may not work very well as their forward voltage drop decreases as they heat up, unless you can accept having them at lower brightness until they are warm which shouldn't take very long.
        However things get easier if you can determine the forward voltage needed at the target current, which is something you can test and measure. If a 24V PSU would do the job things get a lot easier and cheaper as you can get 24V laptop PSU off eBay and elsewhere for about $10 to $20. Even the crude generics should be capable of more than 16.8W, though as always the generics are most likely to have poor capacitors in them. I found about 150 listed on ebay by just searching for "24V laptop".
        It all comes back to how the LEDs are wired. If there are 8 in each series, then 35 parallel series will have about 0.7A total current. There are a few 24V 1A switches I saw on ebay for about $6 delivered when I searched "24V switching".
        • mariushm
          • May 2011
          • 3799
          Exactly, figure out how that panel is made first.
          With so little loads, you could actually even make your own.
          A 20 V AC 1.5A transformer is 15$ : http://search.digikey.com/us/en/prod...1052-ND/952922
          With a 0.5$ bridge rectifier you get about 28v DC, 1A+ from it. That's close enough, you can just play with the resistor value to limit the current through the chains of leds. It's not regulated, but leds don't really care about it. if you really want to... you can use a linear regulator to drop the ~28v to a fixed 24-26v. Something like LM350 should work : http://search.digikey.com/us/en/prod...0TFS-ND/458688
          For such low loads, there's no need for switching power supplies unless you need the psu to be very thin.
          • ReverendJones
            Resurgam
            • May 2010
            • 49
            The rating on the LED panels is 24vdc @ 0.4 amps.
            http://www.goldmine-elec-products.co...?number=G17973
            Machina improba! Vel mihi ede potum vel mihi redde nummos meos!
            • 999999999
              • Sep 2006
              • 774
              If they are going to be used as general lighting that stays on several hours a week or longer, I'd definitely go with a switching PSU, IF it's not going to run outside where temperature extremes could be a problem, to save power.
              Thanks for the link RJ. It does seem to be 8 LEDs per series, or at least that would make the most sense. I'd just get the best quality fixed 24V / 1A switching PSU I could find on ebay that doesn't have a permanently sealed casing so if I ever wanted to open it, I'd only need a screwdriver instead of a vice and prying tool.
              I'm still confused though, with the panel spec'd to run from 24V and 24V PSU available, what need is there to buy new PSU that the plan is to hack them or is this meant to be some sort of dimmer circuit for the light? If so, it seems as though you might need a fixed value resistor in series somewhere with the POT so that the value never goes out of bounds to cause the voltage to get too high as it did previously. Without knowing exactly how the circuit is arranged that's all I can suggest, that I am assuming it's just taking the feedback through a voltage divider made of resistors you are replacing with the pot and with the pot at one end of its rotation, there is not enough resistance in the voltage divider section of the circuit to keep voltage from rising too high.
                • Jul 2011
                • 6057
                Thanks to all that reply to this post
                ....> No there is no heat sink
                $40 for a 120W PSU seems overkill. Mariushm mentioned the issue of how the LEDs are arranged, have you determined they are actually wire as parallel runs of 8 LEDs in each series?...> Yes they are set this way
                .....> (with a series resistor on each series of LEDs.)
                <.......( they are on the board)
                Trying to adjust the PSU to some exact voltage....>
                to adj brightness of the leds with out removing the series resistor on the board <......
                  by sam_sam_sam
                  03-31-2024, 02:12 PM
                  HP EliteBook 850 G7 + Thunderbolt Dock 120W G2 Notebook 800 Specification for Upgrade or Repair
                  This specification for the HP EliteBook 850 G7 + Thunderbolt Dock 120W G2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 850 G7 + Thunderbolt Dock 120W G2 boardview and 850 G7 + Thunderbolt Dock 120W G2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                  09-06-2024, 08:10 PM
                  HP EliteBook 840 G7 + Thunderbolt Dock 120W G2 Ultraportable 800 Specification for Upgrade or Repair
                  This specification for the HP EliteBook 840 G7 + Thunderbolt Dock 120W G2 Ultraportable can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 840 G7 + Thunderbolt Dock 120W G2 boardview and 840 G7 + Thunderbolt Dock 120W G2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                  HP EliteBook 830 G7 + Thunderbolt Dock 120W G2 Notebook 800 Specification for Upgrade or Repair
                  This specification for the HP EliteBook 830 G7 + Thunderbolt Dock 120W G2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 830 G7 + Thunderbolt Dock 120W G2 boardview and 830 G7 + Thunderbolt Dock 120W G2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                  HP EliteBook x360 1030 G4 + Thunderbolt Dock 120W G2 Hybrid (2-in-1) Specification for Upgrade or Repair
                  This specification for the HP EliteBook x360 1030 G4 + Thunderbolt Dock 120W G2 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1030 G4 + Thunderbolt Dock 120W G2 boardview and 1030 G4 + Thunderbolt Dock 120W G2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                  09-06-2024, 06:20 PM
