Power management Block -Charge Pump - RF
  • shaikss
    • Feb 2012
    • India
    Hi Folks,
    I tried designing a Dickson's charge pump.
    Here are the below observations:
    For a voltage doubler:
    When W=240nm, charge pump capacitance= load capacitance= 1p F, load resistance= 10M ohm, Switching frequency=500k Hz, Vin=2V
    Results:
    Vout= 4.3772V, settling time= 50u s (4.3366V).
    Here settling time refers to time at which output have a constant value.
    1. I tried to increase the switching frequency to 500M Hz, peak of output voltage ripple is slightly decreasing.
    2. Decreasing the load resistance resulted in the increase of output ripple.
    3. When I try to lower the switching frequency, the load resistance required to have reasonable output is increasing.
    4. With constant load resistance: if load capacitance increases then settling time increases and ripple decreases but output is same.
    5. With constant load capacitance: if load resistance decreases then output decreases and ripple increases but settling time is same.
    6. with an increase in the charge pump capacitance, settling time and output voltage decreases.
    7. With an increase in 'w' of nmos : best results are coming for 240n M for all the frequencies. I assumed that the with the increase in 'W', best results will come. But best results are coming for 240nm width.
    Can you explain me the reason behind all the seven observations?
    Thanks!
  • AJ847.63e
    Testing ATX PSUs under load - Does loading the ATX 24 pin also load EPS & PCIE?
    by AJ847.63e
    Hi Folks,
    Just wanted to clear up a misunderstanding of mine (or what I expect is one). Isn't the 12V rail from the 24 pin, EPS and PCIE separated? IE if I put a power resistor on the ATX 12V pin that is not going to load, thus tell me if the EPS or PCIE rails are fine?
    I was recently watching ArIs from Hardware Busters video on how to properly test ATX PSUs without using 5 figure Croma substations.
    The PCB adapter he used breaks out the 12, 5 and 3.3V pins from the 24 pin and gives you banana plugs to connect to. That is a bit useless is it not? Aren't...
    05-06-2025, 10:37 PM
    HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
    This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
    09-12-2024, 02:20 PM
    HP ProBook 450 G6 + Image Load, Asset Tag & Testntag Notebook 400 Specification for Upgrade or Repair
    This specification for the HP ProBook 450 G6 + Image Load, Asset Tag & Testntag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G6 + Image Load, Asset Tag & Testntag boardview and 450 G6 + Image Load, Asset Tag & Testntag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
    09-06-2024, 10:56 AM
    HP ProBook 450 G6 + Image Load & Asset Tag Notebook 400 Specification for Upgrade or Repair
    This specification for the HP ProBook 450 G6 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G6 + Image Load & Asset Tag boardview and 450 G6 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
    HP ProBook 430 G6 + Image Load & Asset Tag Notebook 400 Specification for Upgrade or Repair
    This specification for the HP ProBook 430 G6 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G6 + Image Load & Asset Tag boardview and 430 G6 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
