11.00V output from 12V rail, Compaq (OEM by Liteon) 250W PSU
  • Phil_123
    • Dec 2005
    • 21
    • Unknown
    Is there any way to increase the voltage output back to a normal level, around +12V?
  • Rainbow
    • Aug 2005
    • 1375
    Re: 11.00V output from 12V rail, Compaq (OEM by Liteon) 250W PSU
    Did you test that under load?
    • Phil_123
      • Dec 2005
      • 21
      • Unknown
      No.
      • tiresias
        • Feb 2006
        • 489
        Originally posted by Phil_123
        No.
        You'll have to do that to obtain a realistic reading of the PSU's 12Vdc output. Many PSUs, even among the "better" brands will give a low, (often out-of-spec low), 12V output will all lines unloaded. You'll see a number of manufacturers state minimum loads for each rail, in addition to the usual maximum.
        I usually use large wirewound resistors to load a PSU, although any other constant resistive load, such as 12V car light bulbs, will also work well.
        • Phil_123
          • Dec 2005
          • 21
          • Unknown
          I use this PSU to power this configuration:
          Intel P3 933Mhz
          Asus CUSL2-C Black Pearl
          NCP PC133 256MB SDRAM
          WD800JB x 2
          Radeon 9600XT
          5 port NEC USB2.0 card
          Aureal Audio sound card
          Liteon 52x32x52x16x combo drive
          Floppy drive
          On the PSU sticker, it says
          +5V 25A \______ Combined max power 145W
          +3.3V 14A /
          +12V 8A
          +5V AUX 1A
          -12V 0.8A
          -5V 0.5A
          Both UNI-T DT830B multimeter and Motherboard Monitor 5 gave me a jumping +12V reading of around +11.00V to +11.53V.
          I experienced random program errors and reboots until I replaced the psu with Seventeam ST-420BKP.
