Re: Suspect Bad PS Apple AcBel API 1PC36
Ok ... tell me how to safely jump off a cliff and I'll probably do it ...
This may take me a bit (fitting it in around some other 'duties') but think I understand the 90%.
Soldering to Pin2 would be next to the square solder pad. (?)
Found a piece of 24ga wire should be good (better than the 16ga next choice)
Need to ask (because I've wondered) - I did the cap soldering with a chisel tip and wonder if I should have used a needle tip. The chisel tip seems to melt the board solder 'almost' before it touches (fast at any rate)?
Measuring the 3.3/5/12 would be as done when checking voltages initially (using a pinout diagram and instructions)?
