JHS-Q05/12-S334 PSU for external HDD case - bad soldering!
  • japlytic
    • Oct 2005
    • 2086
    Recently, I received an external USB 3.5" HDD case with a JHS-Q05/12S334 power supply manufactured my Shenzhen Jinhuasheng Electronic Co. Ltd.
    I decided to try to find the company, but a search for the model number revealed a discussion that one of them have blown up.
    Inside my unit, the component's leads were cut too short, and moving a resistor a little bit made it come out easily. I guess why one of these supplies (as well as others with bad solder joints or components with leads cut too short) blew up because of a bad solder joint or a component lead becoming loose from thermal cycling.
  • azanoletty10
    • Jul 2006
    Re: JHS-Q05/12-S334 PSU for external HDD case - bad soldering!
    Hi
    I have the same power supply and I think it has burnt up (luckily it didn't actually explode).
    I can't find this company either, and was wondering if you know of any other compatible power supply I can use with my hard drive (supposing my hard drive hasn't also burnt up, of course, I can't check that out as I don't have a power supply!)
    Please tell me anything you know
    Thanks!
    • AngusG
      • Mar 2007
      I have the same power supply for my hard drive... I opened it up and it appears one fo the capacitors has gone... I might give it a whirl and try and replace it... if anyone knows where i can get a replacement power supply please let me know!!!
      • comprido
        • Oct 2007
        Hi.
        I arrived here looking for "Power Supply JHS-Q05/12-S334" throught Google.
        My Zaapa 160GB External HD has this power supply and I´d have the same problem with it.
        One time I had to connect the Ext.HD to my PC to make it work. The problem now is that the PSupply has die
        It´s not function and I want to buy another want.
        Well, your posts here are dated from March 2007, have you found it anywhere?
        I´m thinking in buy some from eBay.
        Bye
        • Spuds
          • Nov 2007
          • 5
          Got some pics of my power supply. My power supply just stopped. No evidence of exploding capacitors
          Model JHS-Q05/12-S335
          Dual-voltage: 5V/2A and 12V/2A
          6 pin mini DIN connector.
          Here's the label:
          • Spuds
            • Nov 2007
            • 5
            Here's the freshly-opened unit:
            • Spuds
              • Nov 2007
              • 5
              Here's the top-side of the functional parts:
              • Spuds
                • Nov 2007
                • 5
                Here's the bottom of the functional parts:
                • Spuds
                  • Nov 2007
                  • 5
                  I am interested in purchasing an equivalent replacement. This power supply is for a Coolmax external drive enclosure. Biggest problem is the connector, I think. The 6 pin mini DIN used is not too unusual (it's the same connector as that used by Metal Gear Box) but the voltage assignments are different. The 12v and 5v pins are reversed - so even though I have two power supplies for the Metal Gear Box enclosures, I can't use them. Well, unless I cave and decide to reverse the wires inside the Coolmax unit.
                  Anyway, if you know where I can buy a replacement equivalent (hopefully not from Shenzhen Jinhuasheng Electronic Co.) please leave a post!
                  • xconan
                    • Dec 2007
                    I have the same problem. I didn't know what to call those connectors aka 6 pin mini din connectors. However I have found a seller addonics that sells it for $19 (quite steep) and the only difference is that the input is 0.8A instead of 1.0A http://www.addonics.com/products/pow...2v_adapter.asp
                    Has anyone used this? Does it work? I also have another connector model PAG0342 and it uses 1.2A. When I plug it into my external casing the light on the brick goes out. I don't know if there's a short on it. However if I plug it in to the original casing it's fine.
                    • xconan
                      • Dec 2007
                      Just took a closer look at the JHS-Q05/12-S334 power supply and it is short of a pin. The Addonics has a total of 6 pins instead of 5. Is there an adapter to the 5 pin din or can a pin be removed from the mini 6 pin din for it to work?
                      • rainiero
                        • Mar 2008
                        Hi XCONAN, I just buy JHS-Q05/12S334 power supply similar for my external Hard Disk Zaapa, I bought it through http://www.addonics.com/products/po...12v_adapter.asp, so I hope to work for mi Zaapa HD. When I receive it I gonna tell you something wether work. I think it's gonna working, cause the output DC is similar to the original power suplly that I buy with my Zaapa HD.
                        • rainiero
                          • Mar 2008
                          Thanks for your reply... when I see your message I try to answer,
                          Ciao
                          • dixon
                            • May 2008
                            Has anyone found a replacement power supply that works using 120v?
                            • shdwsclan
                              • May 2008
                              • 4
                              I have the same power suppply. I agree it is a total piece of garbage.
                              It very poorly soldered and uses substandard components....
                              I think I found a solution.
                              This is the exact bottom of this horrible PSU.
                              As you can all see, that the pin out of this drawn on the bottom of this PSU.
                              Though, with all the typos, the PSU itself is inaccurate.
                              The bottom indicates that this is a 5 pin power supply with an extra pin.
                              The left 2 pins are ground.
                              The right 2 pins are 5v.
                              The bottom left pin and the barrel is 12v.
                              This is WRONG.
                              Both bottom pins are 12v. The barrel itself is ground.
                              If you use a multimeter, you can verify this. I tested this on the psu plug itself, and when the psu was plugged into the enclosure, i tested the socket.
                              The proper socket mapping is listed below.
                              I'm not sure if the original (first pic) is a typo, or on purpose.
                              If you would of wired the barrel for 12v, you would of blown the chipset in the enclosure if not the HD itself...
                              The technical term for this is a Type B 6-pin power adapter
                              or
                              a Type B PS/2 power adapter
                              In any case, you can find a descent one here:
                              http://www.bixnet.com/acpoadforexh.html
                              This is the only site that carries them....from what i can see....
                              • shdwsclan
                                • May 2008
                                • 4
                                Here is are some more sites:
                                http://www.bixmarket.com/bixpro/prod...roductid=16214
                                http://www.targa-onlineshop.de/targa...&productId=624
                                (This is a really wierd product, a basic sata controller with the 6-pin din power socket onboard !! Notice, the pin-out is reversed, because the socket is a negative and the plug is a positive)
                                http://ayagroup.com/product.php?productid=16860
                                The pinout is used on devices so far:
                                Coolmax CD-311
                                Targa DataBox II 250
                                Magic Bridge II (Unknown pin configuration)
                                TVisto 3500 (Unknown pin configuration)
                                Products definetly NOT compatible
                                C&C Tech CE92HM
                                or any power adapter made for the Packard Bell Slimline 527 flat panel monitor.
                                OGD 34w-12-5 is a another model with ocrrect pinout
                                NEW !!!!!!!!!!!!!!!!!!
                                These are rare devices though.
                                I found another way of making a psu for this.
                                You can use ANY 3 pin, 4-pin (hard drive molex) or 5-pin adapter.
                                You basically crack the thing open, remove the old plug and solder in the new plug.
                                All of these plugs are wire using only 3 wires: 1x ground, 1x 5v, 1x 12v.
                                Its cheaper that way, and you can get a much more reliable power supply that way. As long as its 2a output on both 5v and 12v....it has has power...both the controller and the hard drive...
                                NOW THE HARD PART !!!!!!!!!!!!!!
                                Finding a power supply to gut that has 3+ pins, 2a per voltage and is NOT MADE IN CHINA !!!!!!!
                                I will post some if I find some later
                                • shdwsclan
                                  • May 2008
                                  • 4
                                  Harder to find than I thought.
                                  I suggest the 4-pin lacie adapter.....
                                  Its made in china, but its made by a reputable company....lacie...not some no-name...
                                  • shdwsclan
                                    • May 2008
                                    • 4
                                    I bought the lacie 54 watt replacement power supply.
                                    The hard drive takes 2 amps and the power supply can give about 3/5 amps max.
                                    Also, another important thing to not that may be damaging these power supplies, that I didnt mention before.
                                    Some hard drives require more amperage, and thus, if more is required, then the hard drive will try to overload the power supply to get its required power, thus making the power supply hot and eventually burn out...as happened here...
                                    • antipsychotic
                                      • Feb 2011
                                      why not use a power supply used for CPU? modify the cable to match the peripheral connector from the power supply.
                                        by sam_sam_sam
                                        07-01-2024, 06:34 AM
                                        ASUS E410MA-BV190TS-CASE Notebook Specification for Upgrade or Repair
                                        This specification for the ASUS E410MA-BV190TS-CASE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the E410MA-BV190TS-CASE boardview and E410MA-BV190TS-CASE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                        09-06-2024, 10:50 PM
                                        ASUS VivoBook X712FA-AU311R-CASE Notebook 17 Specification for Upgrade or Repair
                                        This specification for the ASUS VivoBook X712FA-AU311R-CASE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X712FA-AU311R-CASE boardview and X712FA-AU311R-CASE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                        09-06-2024, 11:05 AM
                                        ASUS X712FA-AU306T-CASE Notebook Specification for Upgrade or Repair
                                        This specification for the ASUS X712FA-AU306T-CASE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X712FA-AU306T-CASE boardview and X712FA-AU306T-CASE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                        ASUS 571GT-AL188R-CASE Notebook Specification for Upgrade or Repair
                                        This specification for the ASUS 571GT-AL188R-CASE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 571GT-AL188R-CASE boardview and 571GT-AL188R-CASE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
