need HP g6 1130sl boardview file
  • kusal
    • Jul 2021
    • 28
    • Sri Lanka
    ols need help for board view file pls
  • kusal
    • Jul 2021
    • 28
    • Sri Lanka
    Re: need HP g6 1130sl boardview file
    any one pls
    • mon2
      • 14084
      Hi. Not sure if one exists for this unit.
      1) Can you post other markings on the board that may help to locate the file or a similar one ?
      2) what is the fault of the unit ?
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
      • sfernandes
        Sega Dreamcast NTSC-U Revision 0 Launch Unit GD ROM PCB Board Short
        by sfernandes
        Symptom: When I press the power button the power LED lights up for a second and the fan etc spins for a second then the unit turns itself off and will not do the same thing again unless I unplug the power cable for a few minutes then plug it back in otherwise if I just turn the power switch off and back on right after it comes on for a second it will not come on again unless like I said unplug the power cord for a few minutes then plug it back in.
        What I have done to try to isolate the issue so far:
        The system powers on and stays on with...
        01-23-2023, 06:03 PM
      • howardc64
        by howardc64
        07-24-2025, 05:17 PM
      • alegatorul
        Cello Tv . wifi 40" board HK.T.RT2841P638 wrong file update
        by alegatorul
        hi,
        i've being using this Cello tv, uk brand, C40rts, HK.T.RT2841P638 main board, for a year or more.
        Last week i've found an update, 3rd party, that i though it was close to my board. Inserted on a usb stick the install.img, started the Firmware update, ended, rebooted and nothing. The led (red-green) keeps flashing, backlight is on but to response on remote.
        I've retried with original fw, no success. Hooked the uart Cp2102, putty, tried to swuu command (to update from usb), it goes for a while the get "cpu reset" on laptop screen that brakes the process and halt....
        11-03-2024, 02:28 AM
      • Dr Techno
        Motherboard Schematic and BoardView file for a AORUS 15P XC please
        by Dr Techno
        Hi Guys,
        I need a motherboard schematic for file for a AORUS 15P XC please. The EXACT motherboard is ga-rx5lxc rev2.0. It currently has a black screen issue and doesn't display to external display but boots into windows and can also display externally when running ubuntu. If anyone has a motherboard schematic file and boardview for this laptop it would be greatly appreciated. Thanks in advance!​
        05-01-2025, 01:45 PM
