ASUS ROG G513 Schematic + Boardview Needed
    Hi All,
    I have a Asus ROG G513 with no power, no signs of liquid damage.
    Need the Scehematic and Boardview
    Re: ASUS ROG G513 Schematic + Boardview Needed
    Originally posted by AppleTechSupply View Post
    Hi All,
    Whats the silkscreened motherboard part number ?
      Boardview asus G513-6050A3249301-MB-A03 (a3)
      Need the Scehematic and Boardview asus G513-6050A3249301-MB-A03 (a3)
        Re: Boardview asus G513-6050A3249301-MB-A03 (a3)
        G513-6050a3249301 - mb-a04 board view
          i need boardview and schematic anyone help ?
            I need tooo
              Asus G513
              Hey matt do you have the schematic for the 513's?
              I have one that i have no power on i think it might be the same issue you were running into. Thanks
                Here you go, used to repair G533-6050A3250201 6050A3250203
                  And board view
                    Also looking for a motherboard schematic Rog Strix G15 513RW
                      Is it convenient to provide a password to open it?
                        Are they suitable for ASUS ROG Strix G513RW laptop???
                          Any help?
                            ASUS ROG STRIX G15 G513RW
                            PCB marking :
                            G513R-MP-VGT
                            6050A3348803 - MB - A02
                            2021-12-14
                              Really thank you very much for your support!
                                thanks. Nice share
                                  Anyone know if these boards use a cmos battery or a soldered on capacitor? If so where? I need to locate it to reset bios.
                                    The RTC is powered from the main battery,there is no CMOS battery.
                                      So if there is no cmos is there any other path to try the bios? I've tried draining battery, I've tried disconnecting battery and all from mobo and then draining residual power from mobo and nothing has reset the bios.
                                        The bios has NVRAM ,non volatile ram.There`s a few ways to reset it.If the laptop boots into the bios reset defaults.If it won`t boot here`s a risky method,which i won`t talk about as it could cause further damage.The safest way is to make a bios backup using an SPI programmer,then post your backup in the bios requests sub forum,and someone will help you fix it.
