Asus FX505DT Schematic + Boarview
  • Hermond
    • Jun 2021
    • 11
    • Argentina
    Hello there, I am looking for a schematic and if possible a boardview for an Asus FX505DT - BQ403T.
    Trying to identify a component that is heating up. See attachment.
    Visible code on component is 3F=7A 26Z
    Any help would be welcomed.
    Cheers!
  • mon2
    • Dec 2019
    • 13903
    Re: Asus FX505DT Schematic + Boarview
    This is RICHTEK p/n RT6575BGQW.
    Datasheet is attached.
    When sourcing a replacement, be 100% sure that the 'B' suffix is in the part number. This defines that the 3v3 and the 5v0 LDO rails are ALWAYS ON and will match the original p/n.
    • Hermond
      • Jun 2021
      • 11
      • Argentina
      Thank you very much kind sir, and will do make sure to check things well. Hats off to you.
      Cheers.
      • cocobill
        • Jun 2016
        • Greece
        Hello everyone!
        I have a similar board, Asus FX505DT - BQ030T.
        I mosfet was burnt and when I removed it from the board, the short was gone.
        I have no doner board. What mosfet is it? Have a look at the attachments.
        It reads E6932 GA0A1E
        Can anyone help?
        Thank you!
          • 20492
          Originally posted by cocobill
          Hello everyone!
          Can anyone help?
          Thank you!
          The logo at the top left is Alpha Omega https://www.badcaps.net/forum/showpo...7&postcount=15
          AOE6932 https://cdn.badcaps-static.com/pdfs/...acdf91bd1f.pdf
          • asustuf
            • Feb 2023
            • 18
            • Austria
            Hello, have the same mainboard and (I think one capacitor) is creating sparks and doesn't work so laptop won't turn on. Does someone know of what specification are the most upper caps in reverse "L" shape?
            edit: put picture in attachment
            • Zeon7
              • Feb 2023
              • 7
              • Ukraine
              Both are 10UF/25V 0805 X5R/+/-10%
              • ammıknatısık
                • Jan 2021
                • turkıye
                need schematic
                thank you.
                • kalle55
                  • Jan 2022
                  got the same Board. after visual inspection found that component(on the pic) what looks temperate with.
                  is it a capacator or induktor?
                  any schematics or boardviews?
                  • Lisa Su
                    Badcaps
                    • Apr 2021
                    • 213
                    • Taiwan
                    Inductor
                    Schematic & Boardview
                    • nitrix
                      • Jan 2023
                      • russia
                      Originally posted by Lisa Su
                      Inductor
                      Thanks!
                      • chandrakant
                        • Nov 2017
                        • 38
                        • india
                        Inductor
                        Thank u
                        • mamate96961
                          • Jul 2024
                          • france
                          hello, i have the same motherboard and a component that is heating up. can you help me ? on this there is : 3T=7C354
                          Thanks for your help !
                            • 20492
                            3T= mentioned in a post by mon2 https://www.badcaps.net/forum/troubl...76#post3251276
                            • Rofix
                              ASUS PRIME X299 - A schematic or boarview
                              by Rofix
                              Hi everyone, I wanted to kindly ask you if anyone has the schematic or boarview of this motherboard, ASUS PRIME X299 - A
                              thanks in advance for your help
                              12-26-2023, 04:28 PM
                            • viogrand
                              ASUS FX505DT - HN540 schematic
                              by viogrand
                              Hi, someone have schematic and boardview for Asus FX505DT, please?
                              Thank you!
                              12-03-2022, 03:33 AM
                            • ngngocson113
                              I need schematic or boarview colorful CF-B365M-HD V21
                              by ngngocson113
                              Hi everyone.
                              I need schematic or boarview mainboar colorful CF-B365M-HD V21
                              please share with me. thanks:
                              Error description : Can not turn on power. But when forced to turn on the power ( green wire to ground ). Can turn on power and use ok.
                              So, I think the circuit from Sio to green wire ( atx power ) is broken.but i don't know what electronic components it goes through.
                              Anyone know, can you show me where that electronic component is located on the motherboard? share schematic with me please . thanks:
                              04-03-2025, 09:23 PM
                            • whatamidoing
                              Boardview/schematic for an ASUS E3-PRO V5
                              by whatamidoing
                              i'm looking for a schematic/boardview for an ASUS E3-PRO V5 (NOT E3 PRO GAMING, has a different layout).
                              I'm trying to find out where i can find SKTOCC# other than from the socket in order to ground it for a Coffee Lake mod. It must be somewhere near/around the SIO but I haven't found a datasheet for the NCT5539D this board has.
                              I've also found the schematic for the similarly named E3 PRO GAMING V5 but it has a different SIO so it's not of much help. And I don't trust myself to hold still a multimeter probe on top of a LGA socket pin to find where it comes out the...
                              01-18-2025, 09:17 AM
                            • mysnoopy
                              Asus FX516PC R6.0 schematic
                              by mysnoopy
                              Hello
                              I need schematic for this model ASUS FX516PC R6.0
                              Thanks.
                              12-27-2024, 03:41 PM
