Acer quanta z8g bdv
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Acer quanta z8g bdv
    MB codeAOZ8GMB8EO REV E
    Model :Acer A315-32
    Need boardview to disbale onboard ram. Its shorted.
  • reessi
    Acer Alienware Nitro 5 (GH51G LA-L181P Rev: 1C) & Dell Alienware M15 (GDP50 LA-k452P Rev:1) - Both Shorted PCH (SRKMA)!
    by reessi
    Hello:
    I have both these laptops that appeared to have the same fault so I thought I would have a go at replacing the PCH as something to learn, they both are using the same PCH.
    I started on the ACER:
    Up on connecting power no signs of life but current is consumed from the bench power supply and the PCH is hot.
    All the caps on the top of the PCH are showing 0 ohms and the 3.3v rail is shorted.
    I followed the videos from Sorin, Electronics Repair School on Youtube heating from the bottom to install. I practised on around 10 scrap...
    10-29-2024, 11:31 AM
  • abrahim110
    [Help Needed] Acer Aspire 5 A517-52G โ€“ Removed Onboard RAM, Now Working But Battery Not Charging
    by abrahim110
    ๐Ÿงต [Help] Acer Aspire 5 A517-52G โ€“ Onboard RAM Removed, BIOS Mod Done, Battery Not Charging
    I have an Acer Aspire 5 A517-52G-53NB laptop.
    The onboard (soldered) RAM was faulty, so I physically removed the chip.
    I also successfully modified the BIOS using the SPD Removal Tool โ€“ the laptop now boots fine and works with an 8โ€ฏGB DDR4 SO-DIMM installed.
    โœ… System status:
    • BIOS mod is done (SPD removed)
    • Laptop boots to Windows normally
    • RAM is detected and stable
    โŒ Problem:
    The battery is not charging:
    • Power adapter
    08-06-2025, 06:15 AM
  • b-slayer
    Acer A317-53 need help to disable faulty onboard ram
    by b-slayer
    Hello.
    I have an Acer Aspire A317-53 laptop with faulty onboard ram modules, after online searches, I have only found two options to get it working :
    - first one is to modify le bios to disable the onboard ram.
    - second one is to disable the onboard ram by desoldering some components on the mainboard.
    so after some hours google-ing, i have to give-up the modified bios option, main reason is I couldn't find anywhere a such modified Bios, alternate reason is that if windows update makes a bios update, the problem is always here...
    so i found that my motherboard...
    10-12-2024, 03:46 AM
    09-06-2024, 05:27 AM
    Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook 3 Specification for Upgrade or Repair
    This specification for the Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Swift 3 Ultraschlankes Notebook boardview and Acer Swift 3 Ultraschlankes Notebook schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
    09-07-2024, 05:00 AM
