Acer AS3EA_UMA datasheet
  • newnoob
    • Sep 2016
    • 18
    • Italy
    Anybody that have this datasheet?
    need to repair line that charge battary is ko.
    many thanks
    • 21922
    Re: Acer AS3EA_UMA datasheet
    many thanks
    Boardview https://www.badcaps.net/forum/showthread.php?t=84021
    • newnoob
      • Sep 2016
      • 18
      • Italy
      Originally posted by SMDFlea
      many thanks for the reply but in thid bv i dont have name of components or their value.
      i have the short on Q8804
      • stingerchamp
        • Sep 2020
        • 425
        • Pakistan
        You can check Mosfet n channel or p channel just checking names if Name ends with odd digit N channel if even P channel
        Second way check Source pins( 1,2,3) and Drain (5,6,7,8) via multi meter
        mosfet will conduct in one way if we put probe at Drain( Red Probe) and other probe at Source and mosfet shows value it is P channel
        if shows in opposite it is N channel and if it shows values at both then mosfet is likely shorted.
        https://datasheetspdf.com/pdf/100154...s/DMN2027UPS/1
        Q8804
        Q8802 DMN2027UPS_13 , It is a N channel Mosfet
          • 21922
          Q8804
          Most of the time a mosfet with an odd digit is P channel, and even digits are N channel. Its up to the manufacturer what part numbers they give them, so its always better to check the datasheet .
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            I agree with@smdflea that most of the time mosfet with odd marking are "P" Channel and even marking are "N" Channel. But its not universal and checking with datasheet is a must. Consider MDU1511- its odd number, so seems like P channel but its a N channel mosfet. So be sure by checking datasheet.
            • stingerchamp
              • Sep 2020
              • 425
              • Pakistan
              Read my post carefully.
              i will believe when i see a N channel mosfet with even last digit marking.
              • piernov
                • Jan 2016
                • 4439
                • France
                Like the most common one, 2N7002?
                It doesn't matter anyway, just check symbol on schematics and datasheet.
                • stingerchamp
                  • Sep 2020
                  • 425
                  • Pakistan
                  Deadlock.
                  • newnoob
                    • Sep 2016
                    • 18
                    • Italy
                    many thanks for reply.
                    solved
                    changed the 2 mosfet all ok.
                      09-06-2024, 05:27 AM
                    • mkdj
                      Acer Swift won't boot after a Linux install
                      by mkdj
                      Dear all,
                      I have an issue with an Acer Swift laptop which won't boot (Acer Swift SF113-31-C7UK)
                      History and symptoms:
                      A friend of mine tried to install Linux on this laptop. After the installation, the PC did not reboot. When pressing the power button, backlight is working, capslock is working. But screen stays black.
                      What I have done so far:
                      As I suspected a BIOS issue, I tried to clean the TXE region, following the winraid guide for CSE TXE 3.1. I managed to do all the steps, including the steps involving the signing process with OpenSSH. The...
                      10-30-2025, 04:31 AM
                    • sheffieldyorky
                      ZAB/ZAB A,B/ZYJA BLOCK DIAGRAM Acer Aspire
                      by sheffieldyorky
                      Hey there people
                      While working on my Acer Aspire with the OS failing to load, I encountered a motherboard number of DA0ZHQMB6E 0 REV: E. I was getting nowhere fast or slow, for that matter.
                      This is what I tried, but not in any order.
                      Google
                      YouTube
                      BIOS
                      Command Prompt (administrator privileges)
                      On Google AND YouTube, I was getting mixed messages, try this and try that, but when you cross reference the advice it is either the wrong model (even though you enter the correct search term) a YouTube case in point, with the search term "how to...
                      10-25-2025, 02:22 AM
                    • DeXXter
                      [Question] Acer nitro 5 image on HDMI without screen
                      by DeXXter
                      Hello, I was offered an acer nitro 5 motherboard (i5 10300h + gtx 1650) and I have this little question, is it possible to just connect this motherboard through hdmi and have picture and access the bios without the drivers and windows? because I don't have the display for this one.
                      I had an old acer with ryzen 2500u without display that was able to access the bios using hdmi only, but with this intel model I don't know. So it would be appreciated if someone knows if this is possible.
                      Thanks!
                      09-25-2025, 09:48 PM
                    • wasyl
                      Acer Nitro AN515-46 HH51R LA-M002P R1A BoardView File + schematic
                      by wasyl
                      Hi, did not found here so uploading to help...
                      09-15-2025, 07:40 AM
