hp 15 ZSO51 LA-A996p shematic diagram
  • kadi144
    • Aug 2015
    • 690
    • algerie
    hi all members
    i seek a HP15 ZSO51 LA-A996p Rev 1.0
    2013-10-30
    and need a shematic diagram
    thanks in advance
    merci
    • 21446
    Re: hp 15 ZSO51 LA-A996p shematic diagram
    Use the forum search, you`ll find it "LA-A996P"
    • kadi144
      • Aug 2015
      • 690
      • algerie
      i h ve Use the forum search, founding only bios
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        Here it is friend.
        • kadi144
          • Aug 2015
          • 690
          • algerie
          many thanks herr.mcplslg123
          • ChrisH87
            • Mar 2021
            • United Kingdom
            Does anyone know if there is a board layout diagram available for this board of just the schematic as above? Currently trying to diagnose a CPU error but need to know cap locations to probe the board.
            Board posted and booted fine last week but no gives single flash on caps lock indicating CPU fault?
            • tonytou30
              as5304t v1.4 shematic diagram
              by tonytou30
              Hi everybody,
              someone can post me the as5304t v1.4 (asustor) shelmatic diagram please?
              if no someone can help me to find the probleme with this board (faulty ground...)
              thanks in advance
              02-09-2025, 02:28 AM
            • hs5424
              Dynacord powermate 1600 block diagram.
              by hs5424
              Hi All,
              I obtained a schematic diagram for the above mixer but I am wondering if a block diagram exists as I am trying to fix a problem in the protection circuit which I find a little confusing using a circuit diagram only. In the good old days the workshop manuals always had a block diagram with a circuit discription. Very useful for fault finding.
              The protection light is perminently on. The right sode has a -80DC on the feed to the speaker, hence the protection led on. I have removed all the O/P transistors which checked out OK. I tested all other transistors in circuit which seem...
              07-31-2025, 01:35 PM
            • kadi144
              TECRA C50-B1271 shematic diagram
              by kadi144
              i need a TECRA C50-B1271 shematic diagram
              TECRA C50-B1271 I3
              PART NO.PSSG5V
              the mother board is;
              falesy1
              a5a003821010a
              thank you all
              07-15-2021, 09:51 PM
            • gabri2211
              I'm looking for the wiring diagram for led monitor model DHI-LM19-L200
              by gabri2211
              hello everyone, I'm looking for the wiring diagram of this led monitor.
              the model is DHI-LM19-L200, but I think that any other diagram of a DAHUA monitor could be equivalent.
              I really hope that among you someone can help me to repair this monitor, the screen is black, it doesn't seem like a backlight problem.
              I see the presence of 12 volts, 5 volts, but without a diagram the repair is very difficult.
              thanks to those who will answer
              12-10-2024, 04:37 PM
            • kadi144
              DELL Latitude E7250 Shematic diagram need
              by kadi144
              hi all
              iseek DELL Latitude E7250 Shematic diagram
              ZBZ00 LA-A971P
              REV 1.0(A00
              2014-10-09
              06-10-2020, 05:31 PM
