Dell 15-3000 Janus _intel-mb 13302-1 Schematic
    Hi!
    Problem is as adapter is connected to board, fans stays on continuously (U3601)5016 is getting heated
    3.3 volts ,5 volts present ok .
    where to start from
    Model Details
    Janus _intel-mb
    13302-1
    PPWB. MRF1C REV:AOO.
    tehankyou
      Re: Need Dell Inspiron 3542 Schematic Diagram Urgent...
      omg...thx man.....in 2018 =DDDDD
        thank u
          Re: Dell 15-3000 Janus _intel-mb 13302-1 Schematic
          Same board, PU4503 heating this time.
            After changing IO chip ,no more heating.missing 5V_S0 .Power present at coil (PL4902) .board turns on . where to start from
              DDR_VREF_S3(0.75V) Present??
                Sorry for delay update ,its showing (0.678 v)
                  0.678v is corrrect. You need to check U3601. You have 3v3_S0- right?? Both 3v & 5V S0 are enabled by PM_SLP_S3#-so it cant be missing. The only thing i can conclude is you have some sort of shorted component on 5V_S0. What is the resistance on pin13-14 of U3601?? Have you checked u3502/3503/3504 for shorting??
                    No, when board came pu4503 was heating , after replacing Q2402,kbc24 (NPCE985)
                    i will check as your given details ,Thanks for your guide .
                      Now, i'm confused. You mean you dont have PM_SLP_S3# ???? I've read your post about pu4503 heating and kbc replacement. Please clarify. Btw, what is your Dc consumption -offline and online??
                        Yes Don't have PM_SLP_S3#, no activity at all
                        DC consumption both on & off 0.01
                        checked u3503,3504,3505,
                        a doubt pc4523 is missing or it ok,
                          PM_SLP_S3# is missing so you need to get backwards. Check the following:
                          01.RTCRST#
                          02.VCCDSW
                          03.DPWROK
                          04.BATLOW#
                          05.SLP_SUS#
                          06.VCCSUS#
                          07.RSMRST#
                          08.SUSWARN#
                          09.SUSCLK
                          10.ACPREsent
                          11.SUS_ACK#
