Help : plug in not charging, how do i trace the fault on schematic?
  • Udemzy
    • May 2017
    • 155
    • Guatemala
    Hello Engineers, I have a Dell 3251 LA-9104p, it says plug in not charging on desktop.
    I've change charger and battery, still the same thing.
    I downloaded the schematic but I'm finding it difficult to trace the fault as I'm new to schematic reading.
    I have attached the schematic below, pls help.
  • jasko_jacker
    • Oct 2014
    • 1137
    • italy
    Re: Help : plug in not charging, how do i trace the fault on schematic?
    It's not simple if you haven't a basic knowledge on electronics repair, the power section
    start at pag 44 and 45 , but if the notebook start but not charge check if the power adaptor is exactly for this model otherwaise it run but not charge
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      You need to measure voltage on all pins of charger ic and post here. Be careful while measuring or else the mb may be damaged. Are you getting PS id signal 3.3v?? have you checked the two mosfets just after dc jack-most probably 4407??
      • flat-earther
        ASUS X54H laptop thinks it's always charging even with charger unplugged
        by flat-earther
        The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
        Windows also shows ''Plugged in'' when charger is not connected.
        This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
        Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
        If I let battery run out and say it has 3% Windows will...
        06-24-2025, 09:32 AM
      • ianpoultonknights
        Zenbook Flip 15 UX562AI schematic
        by ianpoultonknights
        Had one of these come in for repair with a blown battery and a WiFi issue, battery has been replaced with genuine battery (twice) and won't take a charge works fine on AC, WiFi issue gone away. Looking for a schematic so I can trace the charger circuit UM562F is only one I can find, this is the 562AI model.Had a unit come in for repair — 562AI model — with a blown battery and WiFi issue. WiFi fault has cleared, but battery won’t charge despite replacing it twice with genuine parts. Device operates fine on AC power. Suspect charger circuit fault. Only schematic I’ve found so far is for...
        06-26-2025, 02:41 PM
      • Scoff
        HP Probook 470 G4 - Power and Charging Problem
        by Scoff
        Looking for some help with this one if anybody can assist please? I have an HP Probook 470 G4 Laptop which recently started to intermittently failing to turn on, with intermittent white LED light(charging LED) by the charging port when it should have been charging and showing an orange LED instead. Definitely some sort of gradual failure. Now the laptop fails to power on at all, no charging LED, no Power Button LED either - seemingly dead.
        Stripped down to the bare motherboard. The original HP battery, when disconnected from the motherboard, is reading 0.00v - possibly some sort of protection...
        07-03-2023, 09:28 AM
      • OKRPKCOMP
        Amazing battery charging fault Dell Vostro 3578
        by OKRPKCOMP
        My laptop is not charging batery but when i repalce bios, batery charging starts but there is service tag enter error, and when i enter service tag, it again not charging batery. confusing
        Service Tag: 562N2P2
        board code: vegas turis mlk kbl-r 17841-1...
        09-11-2023, 10:34 AM
      • horsebatterystaple
        XPS 13 7390 2-in-1. No Power On.
        by horsebatterystaple
        I've got a XPS 13 7390 (2-in-1 variant) that I've used every day without issue for 2.5 to 3 years now. Specs and failure info are below. This model has an SSD that's soldered to the board with some very important information on it that I need back. I have a bit of experience in electronics repair from years ago (my dad was one of the first-gen computer repairmen, but most of my knowledge is from desktop motherboards with interchangeable components-- not netbooks with microsoldering. Pointers would be very much appreciated.
        It should go without saying that I did only cursory research...
        06-21-2022, 08:30 AM
