SONY SVF152 schematic required
  • inflex
    • Aug 2012
    • 545
    Require schematic for the SVF152 SONY VAIO.
    Please note, this is *not* the same as the SVF15 (sony-svf15-da0hk9mb6d0hkd-hkc-hk9embhsw-.pdf which I've obtained already).
    Specifically there should be parts like PU5 and PR70 in the schematic.
    EDIT-UPDATE: Seems I've found what I need in the SV142A schematic. Has the CPU VCC_CORE generator which is the ISL95837HRZ-T
    YouTube Repair Videos - https://www.youtube.com/user/19PLD73
    FlexBV BoardView software - Linux/OSX/Windows - http://pldaniels.com/flexbv
  • Elsid79
    • Aug 2015
    • 47
    • Ukraine
    Re: SONY SVF152 schematic required (FOUND)
    the same is true for SVF142C29L/SVF14218CXB (Quanta Chief River DA08HKMB6E0
    • indu
      • May 2015
      • 30
      • srilanka
      i need sony mbx-243 schemaics
      • alterr333
        • May 2019
        • 43
        • México
        Thanks mate, thats the one i've been looking for.
        Now i need to determine were th e fault is, Laptop boots and keeps looping between 600-750 mah
        Till something happens and the backlight enables then the computer works great, untill you reboot it, or shut it off.
        • alterr333
          • May 2019
          • 43
          • México
          If you use this software, called xinzhizao you'll be able to read such schematics
          http://global.wmdang.com/index/index...ter/46649.html
          Cheers mate
