MSI X465 schematic needed...
+ More Options
Posts
  • tazmaniand1221
    • Apr 2016
    • Philippines
    Gud day .. i have a laptop when i turn on only power led and hdd led light only..
    when i check the board ther is no supply in the processor..
    Is there anybody has the schematic of MSI X465 wid board id: MS-14551 VER:1.1.
    TIA..
  • mcoytzhi27
    Mr
    • Nov 2015
    • 43
    • philippines
    Re: MSI X465 schematic needed...
    Try remove nectoken and replace tantalum capacitor
    • boss juben
      • Oct 2016
      • 37
      • philippines
      try to replace pu3 or pu4 it will works 100%
      • knk2729
        dag3bembcd0 rev d Board view and Schematic needed for Non Graphic Conversion (DIS to UMA) as the Graphic chip is bad
        by knk2729
        06-23-2025, 07:09 PM
      • Ven
        Dynabook Satellite Pro L40-G-102 Schematic Needed
        by Ven
        Dynabook Satellite Pro L40-G-102 Schematic Needed.
        02-24-2025, 06:21 AM
      • re-atari
        Gigabyte GA-H110-D3A schematic/boardview needed
        by re-atari
        Hello all,
        Does anybody have a schematic and/or boardview of the Gigabyte GA-H110-D3A mainboard available? It would really help me out big time...
        This board was donated to me in a known non-working state. In its previous life it was used as a mining board, so I suspected bad caps and a relatively easy fix. My intention is to use the fixed board as a testbed for a Truenas or Unraid build. The previous owner told me that the mainboard started to act 'weirdly' after replacing the originally installed Celeron for an i5-6400, varying from starting up irregularly to not at...
        02-24-2025, 06:45 PM
      • camisao
        MSI GF63 12UDX-234XPT - MS-16R81 VER:2.0 - Schematic needed
        by camisao
        I need your help finding the MSI GF63 12UDX (Board MS-16R81 VER_2.0) schematic.
        I accidently inserted MSI USB a programmer that was connected to a board that has Neutral tied to GND, instead of connecting it to the USB-ISO that was on another port (Friday afternoon mistakes....).
        Now it doesn't start. 😏
        I've looked for burned parts but found none.
        The 20V from the adapter are ok and the battery has 12V if I disconnect the battery plug.
        I need the schematic to try to understand where there the problem may be or if it is repairable.
        Thanks!...
        12-02-2024, 05:30 AM
      • Gau_saha
        Schematic needed GA-H61M-S REV1.1
        by Gau_saha
        Sir ,
        I need the schematic of h61m-s rev1.1 gigabyte motherboard.
        Recently this board came to me for repair but could not find its schematic .
        The problem of this board is no display but the board has a power on it .Processor is not heating .
        For preliminary investigation i changed vga cable ,ram and processor but the same issue persist.
        Whenever i switch on the motherboard monitor says NO SIGNAL .
        The board is almost new .No sign of corrosion on the board seen .
        10-16-2024, 08:48 AM
