NEWTON_BR_HPC Schematic needed
  • pcnetch
    • Aug 2013
    • 125
    • Sri Lanka
    Hi any one have schematic for P/N: 010172W00-600-G NEWTON_BR_HPC. Thanks
  • alas3376
    • Nov 2011
    • 382
    • BENIN
    Re: NEWTON_BR_HPC Schematic needed
    Schematic plesae
    • on/off
      • Oct 2016
      • 333
      • Indonesia
      Not Available
      • mina3232
        • Nov 2019
        • luxor
        please i need schematic laptop hp 655 or P/N: 010172W00-600-G NEWTON_BR_HPC
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          Read post#3
          • knk2729
            dag3bembcd0 rev d Board view and Schematic needed for Non Graphic Conversion (DIS to UMA) as the Graphic chip is bad
            by knk2729
            06-23-2025, 07:09 PM
          • Ven
            Dynabook Satellite Pro L40-G-102 Schematic Needed
            by Ven
            Dynabook Satellite Pro L40-G-102 Schematic Needed.
            02-24-2025, 06:21 AM
          • re-atari
            Gigabyte GA-H110-D3A schematic/boardview needed
            by re-atari
            Hello all,
            Does anybody have a schematic and/or boardview of the Gigabyte GA-H110-D3A mainboard available? It would really help me out big time...
            This board was donated to me in a known non-working state. In its previous life it was used as a mining board, so I suspected bad caps and a relatively easy fix. My intention is to use the fixed board as a testbed for a Truenas or Unraid build. The previous owner told me that the mainboard started to act 'weirdly' after replacing the originally installed Celeron for an i5-6400, varying from starting up irregularly to not at...
            02-24-2025, 06:45 PM
          • camisao
            MSI GF63 12UDX-234XPT - MS-16R81 VER:2.0 - Schematic needed
            by camisao
            I need your help finding the MSI GF63 12UDX (Board MS-16R81 VER_2.0) schematic.
            I accidently inserted MSI USB a programmer that was connected to a board that has Neutral tied to GND, instead of connecting it to the USB-ISO that was on another port (Friday afternoon mistakes....).
            Now it doesn't start. 😏
            I've looked for burned parts but found none.
            The 20V from the adapter are ok and the battery has 12V if I disconnect the battery plug.
            I need the schematic to try to understand where there the problem may be or if it is repairable.
            Thanks!...
            12-02-2024, 05:30 AM
          • Gau_saha
            Schematic needed GA-H61M-S REV1.1
            by Gau_saha
            Sir ,
            I need the schematic of h61m-s rev1.1 gigabyte motherboard.
            Recently this board came to me for repair but could not find its schematic .
            The problem of this board is no display but the board has a power on it .Processor is not heating .
            For preliminary investigation i changed vga cable ,ram and processor but the same issue persist.
            Whenever i switch on the motherboard monitor says NO SIGNAL .
            The board is almost new .No sign of corrosion on the board seen .
            10-16-2024, 08:48 AM
