DV14_HR_MB 48.4IU15.01M want Shematic Diagram
  • tonytou30
    as5304t v1.4 shematic diagram
    by tonytou30
    Hi everybody,
    someone can post me the as5304t v1.4 (asustor) shelmatic diagram please?
    if no someone can help me to find the probleme with this board (faulty ground...)
    thanks in advance
    02-09-2025, 02:28 AM
  • hs5424
    Dynacord powermate 1600 block diagram.
    by hs5424
    Hi All,
    I obtained a schematic diagram for the above mixer but I am wondering if a block diagram exists as I am trying to fix a problem in the protection circuit which I find a little confusing using a circuit diagram only. In the good old days the workshop manuals always had a block diagram with a circuit discription. Very useful for fault finding.
    The protection light is perminently on. The right sode has a -80DC on the feed to the speaker, hence the protection led on. I have removed all the O/P transistors which checked out OK. I tested all other transistors in circuit which seem...
    07-31-2025, 01:35 PM
  • SilverbackITGuy
    Asus ROG Strix G17 , Identifying a part number from the boardview diagram ID
    by SilverbackITGuy
    First of all, I hope I got this into the right section. Apologies if I did not.
    I was working on my Asus ROG Strix G17 (2021) G713QM-RS96, and I guess I pre-heated the board too much replacing the DC Jack and one of the small parts came off. I looked for it on my soldering mat, and it was nowhere to be found. So now, the laptop is powered from the new DC Jack I installed, but it will not charge the battery from that jack. Only powers the hardware.
    I looked at the boardview diagram in another post for the G713QM, and it looks like the diagram displays it as X450, a 4 contact...
    11-18-2025, 07:23 PM
  • kadi144
    TECRA C50-B1271 shematic diagram
    by kadi144
    i need a TECRA C50-B1271 shematic diagram
    TECRA C50-B1271 I3
    PART NO.PSSG5V
    the mother board is;
    falesy1
    a5a003821010a
    thank you all
    07-15-2021, 09:51 PM
  • gabri2211
    I'm looking for the wiring diagram for led monitor model DHI-LM19-L200
    by gabri2211
    hello everyone, I'm looking for the wiring diagram of this led monitor.
    the model is DHI-LM19-L200, but I think that any other diagram of a DAHUA monitor could be equivalent.
    I really hope that among you someone can help me to repair this monitor, the screen is black, it doesn't seem like a backlight problem.
    I see the presence of 12 volts, 5 volts, but without a diagram the repair is very difficult.
    thanks to those who will answer
    12-10-2024, 04:37 PM
