HP day0pambaf0 L70767-601 schematic and boardview request
  • techrescue102
    • Scotland
    Would anyone happen to have a boardview and schematic for an HP day0pambaf0 L70767-601 motherboard from a HP elitebook x360 1030 g4?
  • jonyhdtv
    HP ProBook X360 11 G3 ee (winbook) schematic and boardview thanks
    by jonyhdtv
    Looking for schematic and boardview
    Model: HP ProBook X360 11 G3 EE
    Serial: SCG9114JG7
    Motherboard: L43774-601
    defect: touchscreen doesn't work (touch works on another computer)
    thanks to all​
    01-29-2025, 08:16 AM
  • jonyhdtv
    HP ProBook X360 11 G5 ee schematic and boardview thanks
    by jonyhdtv
    HP ProBook X360 11 G5 ee (winbook) schematic and boardview thanks
    Model: HP ProBook X360 11 G5 EE
    Serial: SCG0164QLH
    Motherboard: L83950-601
    defect: no POWER
    thanks to all​
    01-29-2025, 08:11 AM
  • PacoGT
    HP ENVY x360 gidget 8L 203038-1, boardview and schematic need
    by PacoGT
    hello firends
    i search the schematic or boardview
    I have this motherboard, but I can't find the schematic or the boardview.
    The problem is that on the chip marked where 3V should be, there are 5 volts, which indicates that the two are connected.
    So the computer doesn't turn on, and the 3V disappears after a few seconds.
    The original problem was that when I turned off the computer, the fan stayed on and saw that it was bad since it was directly in the 5V area.
    The new problem arose after removing the bad chip.
    3V and 5V remained together,...
    08-19-2025, 08:25 PM
  • hosain0489
    Request for Schematic and Boardview for HP Omen 16-xf0006AX (AMD Ryzen 7 7840H Version)
    by hosain0489
    I’m looking for the schematic and boardview files specifically for the AMD version of the HP Omen 16 laptop, model xf0006AX, equipped with the Ryzen 7 7840H CPU.
    Most of the files I’ve found are for Intel CPU versions, and I need the exact files for this AMD Ryzen 7 7840H model to assist with repair and troubleshooting.
    If anyone has access to these files or can kindly share the boardview and schematic for this particular AMD version, I would really appreciate your support.
    Thank you very much in advance!
    07-15-2025, 11:20 AM
  • javiermi
    HP 14265-2 Fauchon-SKL MB (Pavillion x360 convertible - 13-s150sa) Schematic and/or Boardview request
    by javiermi
    Hi this laptop had liquid damage: I found a couple of burned contacts on the keyboard connector, and it worked for a while after I cleaned them. After that, the keyboard stopped working completely I replaced the sfp connector and still the same. I doubt the problem is the keyboard, as it was working ok until it stopped completely. I suspect either a DC line is broken or there is a fuse failure.
    if I get an schematic I will check.
    There are several compatible boards, the models are: 827824 , 827823 , 809842 depending of the installed CPU
    Alternatively, if somebody can confirm...
    01-08-2024, 05:48 PM
