I'm looking for this schematic diagram
Hi, do you have SONY MBX-271 schematic? please
by Carlos#2003%Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
by titimimohello Guys Titi here ,
hope you are ok,i am looking for help,any one with schematic of IB250CX schematic diagram( lenovo M710e)
mine has an ic above sata has removed and i can't guess the number or if it was a regulator
please if you know let me know the type of this chip
computer work except to recognize hdd or ssd disk ,normally i can't install windows even if disk shows up or run windows
thanks-
by Kirve"Hello friends. My Asus X556U laptop is not charging, not turning on, etc. I wanted to repair the motherboard, partly for learning purposes. One of the capacitors is giving a 24V output, and one of the MOSFET pins is also giving a 24V output, and honestly, this surprises me. I think I need to replace the capacitor, but I don’t know the capacitance value. I tried searching for a motherboard schematic but couldn’t find anything. Can you help me find the schematic or diagram?"
by my2k2Kindly somebody share schematic diagram for Sharp 2T-C42EG1X (Board: QPWBNH1 96WJN1 )
Most of the smd resistors were burned
Thanks in advance...09-05-2025, 10:19 AM -
by geraldkackaCan someone help me with a microsoft Surface Studio 2nd Gen Schematic diagram.
09-05-2025, 03:16 AM -
- Loading...
