HDL10 LA-3111P schematic needed. please help
lenovo3000n100 schematic needed
by ThetechdudeHi guys, I'm working on a MSI Ventus RTX 4080 16G. The GPU has 12v, 5v, however what I assume is the 1.8v rail has 1.1v and what I assume to be PEX is 0v. As you may have guessed already there is no Vmem and no Vcore.
I have looked around in related forum posts for a schematic so Much appreciated if anyone can share a Broadview schematic.
Thanks.-
Channel: Schematics and Boardviews
07-15-2025, 11:15 AM -
by knk2729dag3bembcd0 rev d Board view and Schematic needed for Non Graphic Conversion (DIS to UMA) as the Graphic chip is bad
by re-atariHello all,
Does anybody have a schematic and/or boardview of the Gigabyte GA-H110-D3A mainboard available? It would really help me out big time...
This board was donated to me in a known non-working state. In its previous life it was used as a mining board, so I suspected bad caps and a relatively easy fix. My intention is to use the fixed board as a testbed for a Truenas or Unraid build. The previous owner told me that the mainboard started to act 'weirdly' after replacing the originally installed Celeron for an i5-6400, varying from starting up irregularly to not at...-
by camisaoHello,
I need your help finding the MSI GF63 12UDX (Board MS-16R81 VER_2.0) schematic.
I accidently inserted MSI USB a programmer that was connected to a board that has Neutral tied to GND, instead of connecting it to the USB-ISO that was on another port (Friday afternoon mistakes....).
Now it doesn't start. 😏
I've looked for burned parts but found none.
The 20V from the adapter are ok and the battery has 12V if I disconnect the battery plug.
I need the schematic to try to understand where there the problem may be or if it is repairable.
Thanks!...-
- Loading...
