Kindly help with clean and working dump
Dabklamb8d0 rev D
Tags: None
Re: Dabklamb8d0 rev D
Post your corrupt bios file, full model name, serial number.↵
by CityminHi all,
S/N : 5RNK9FFT70...-
Channel: BIOS Requests ONLY!
by to5it0Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
I have opened the laptop and identified the main BIOS chip...2 Photos-
by CurtissimoHi everyone.
I have a HP Elitebook 850 G8.
Serial: 5CG2324XM0
ProdID 6L8D5EC#ABA
It has a Winbond W25Q256JVEN Chip.
I need to remove BIOS Password.
I made a dump with an CHA341A programmer and NeoProgrammer 2.2.0.10.
Attached my dump.
I also used the HP Unlocker tool to create an unlocked file (I followed the guidelines)
I also downloaded latest HP BIOS Update (SP158137) which includes 3 .bin files. I found the Number T76 in my original dump, so I used: T76_01210000.bin
What I did:...-
I have a Fujitsu Lifebook E547 vPro that does not boot anymore after Windows Update tried to install a new Bios version. Screen stays black no post - only the numblock light blinks.
What I've tried:
I have used my CH341A to read the bios chip (25Q128FVSQ) (Dump attached) - I think the dump is "good" because I could find the Serial number in the data and also the Winkeyfinder found a windows key.
for the lack of any other Idea I took the bios from this post (https://www.badcaps.net/forum/troubl.../troubleshooti...-
by kenzo2I need dump file for nand A2159 512GB with 2 Nand chips >.I upgraded 128gb to 512gb..I use P13 there are only 4Chips...
I need dump file MACBOOK PRO A2159
TSB4232(256)
TSB4229(256)
Thanks - Loading...
