DAX3BBMBAD0 REV D Bios PLS
  • pooya_pm
    • Jan 2021
    • 254
    • iraq
    HP Spectre x360 15t-eb100 DAX3BBMBAD0 REV D Bios
  • hardware1
    • Sep 2021
    • 2930
    • N/A
    Re: DAX3BBMBAD0 REV D Bios PLS
    Upload your original bios file.
    all donations are welcome,
    • pooya_pm
      • Jan 2021
      • 254
      • iraq
      upload your original bios file.
      BACKUP
      sn: 5cd120sd5j
      • qayyum786
        • Aug 2018
        • 1933
        • INDIA
        backup
        sn: 5cd120sd5j
        read bios than post again
        dump is not good
        • pooya_pm
          • Jan 2021
          • 254
          • iraq
          Pls hellp me....
            • 20898
            Pls hellp me....
            did you read post #4 your backup isn`t good. What model is your programmer and software version, are you using Auto-detect , is the chip in the support list , are you using a clip . Is the chip burned or physically damaged , have you soldered wires to the pads and if so how long are the wires.
            It isn`t the first time youve posted a bad backup there must be a reason why. The compressed backup you posted should be over 1MB at least, it should not be KB , when its in the KB its a good indication of a bad backup,you can also open the backup with a hex editor and check to make sure there is some code throughout the file, if the file only has a little bit of code or all FF`s its another bad backup
            • pooya_pm
              • Jan 2021
              • 254
              • iraq
              I am using RT809H
              I remove the IC from the board and put it on the programmer and take a backup
                • 20898
                I am using RT809H
                try making another backup, compare both of your backups using a hex editors file-compare function or some other file comparison software.If the backups are the same or still corrupt its possible the chip is bad or it was a bad bios update.If your next backup has more code than the 1st post it, if not then go to hp support, enter the serial to find the bios update, download it , run the exe and choose the save option, a full virgin bios will be extracted.
                • hoaca388
                  Badcaps
                  • Jan 2022
                  • 11736
                  HP Spectre x360 Convertible Laptop PC 15-eb1043dx
                  • pooya_pm
                    • Jan 2021
                    • 254
                    • iraq
                    Originally posted by hoaca388
                    hp spectre x360 convertible laptop pc 15-eb1043dx
                    thankyou bro
                    workied for me
                    • wishes2022
                      • Nov 2022
                      • 35
                      • china
                      Thank you .it worked
                      • nexttoyou
                        • Aug 2022
                        • nigeria
                        the hp spectre x360 15t-eb100 11th gen was showing bios isusse and now it not coming up please i need help and a working bios for it
                        • Vesko356
                          VIP Moderator
                          • Aug 2018
                          • 4386
                          • Bulgaria 🇧🇬
                          Read the rules before posting:
                          Upload your bios backup and serial number.
                          Become a Badcaps supporter
                          Thanks to all supporters.
                          • Azamkhan
                            • Jan 2024
                            • pakistan
                            hello every one ineed dax3bbmbad0 bios clear share me sn.5cd150b044 and product no 3n385av
                            • peste
                              • Dec 2016
                              • 12792
                              • ROMANIA
                              post the full name and model of the laptop, post the original content of the bios chip, even if it is corrupted..
