Bios lenovo idepad 3 14igl NM-C961 rev 1.0
    Pleas help,
    I need bios for Lenovo Ideapad 3 14IGL kode board NM-C961 rev 1.0...
    Problem is no display.
    Re: Bios lenovo idepad 3 14igl NM-C961 rev 1.0
    Originally posted by cokan kepo View Post
    Pleas help,
    always when you make a bios request, also post the original bios of the laptop, even if it is corrupted..
      this file bios from origin(backup).
        board number :rev: 1.0 nm-c961
        gs453/gs553
        2019-12-27
        need bios
        my dump has no display
        the sticker with serial number is blank i cant get hold of it
          hi everyone can someone please help me the problem for this LENOVO laptop is No Display. the board model is
          GS453/GS553
          NM-C961 REV: 1.0
          2019-12-27
          I attached the original bios. thanks in advance
            GS453/GS553
            NM-C961 REV: 1.0
            2019-12-27
            Post the laptop serial number
              Thank you for the response master smdflea. Sad to say the serial is already erase.
                bios extracted from Lenovo website update for... V14-IGL, V15-IGL, ideapad 3-14IGL05, ideapad 3-15IGL05
                DMI 483000 - 484FFF
                  thank you master peste. il update the result later. thank you very much
                    DMI 483000 - 484FFF
                    Sir i try the bios but still no display. maybe this is not a bios issue. but all voltage are present
                      What voltage do you have on PL6601?
                        out of topic reply so i deleted it
                          Originally posted by Lhybz View Post
                          Hi, Got interested with your question, Im also working on the same model now. All power rails are okay before power on. But when I switched on the unit it just goes on without turning on the display. Upon switched on all signals to turn on the unit is okay. I was wodering about your question, what voltage should I get atn PL6601? If if there is no voltage at all, what do you think is the issue?
                          If you both want help with a hardware problem start a new thread in the laptop troubleshooting forum. This section is for "Bios requests ONLY!"
                            My apologies. I will delete my reply.
                              hello could you help me fix my bios dump. no display and power button blink after i modify some bios settings. thanks
                              read..https://www.badcaps.net/forum/troubl...before-posting
                                DMI 483000 - 484FFF
                                tested, working
                                  Can some clear the ME Region, please
                                    post snid
                                      Originally posted by shiyab View Post
                                      post snid
                                      The sticker is gone... where can I find it? There are some numbers and QR codes con the MB, thanks in advance
