bios password hp elitebook x360 1040 g6
  • abdelilahocs
    • Nov 2018
    • 119
    • morroco
    mother BRIGHTON-6050A3037501-MB-A01(A1)
    pls can anyone help
  • peste
    • Dec 2016
    • 12859
    • ROMANIA
    Re: bios password hp elitebook x360 1040 g6
    pls can anyone help
    post the original bios of the laptop..
    • abdelilahocs
      • Nov 2018
      • 119
      • morroco
      The original bios
        • 20984
        The original bios
        HP BIOS unlock tool https://www.badcaps.net/forum/showth...+g6#post936816
        https://www.badcaps.net/forum/showpo...&postcount=386
        • abdelilahocs
          • Nov 2018
          • 119
          • morroco
          thanks i will tested and reply
          • abdelilahocs
            • Nov 2018
            • 119
            • morroco
            it dosnt work
            • hoaca388
              Badcaps
              • Jan 2022
              • 11798
              it dosnt work
              Find 2nd SPI chip , read it , it's 16MB or 32MB chip.
              • DanielDacko
                • Mar 2015
                • 325
                • Macedonia
                The original bios
                Try this and report back.
                I don't provide help for people using CH341A and a clip.
                • Bolanle
                  • Apr 2023
                  • 17
                  • vn
                  Please help with to remove the computrace
                  • farouk_1994
                    • Mar 2021
                    • 392
                    • algeria
                    Try and feedback
                    • Bolanle
                      • Apr 2023
                      • 17
                      • vn
                      Originally posted by farouk_1994
                      Try and feedback
                      Showing this error
                      • Bolanle
                        • Apr 2023
                        • 17
                        • vn
                        Showing this error
                        Please help me
                        • patcopley1
                          • Jun 2021
                          • 11
                          Hello...I have an HP Elitebook x360 1040 G6 with a POST power-on password and a BIOS supervisor password...I see 2 Winbond chips...25Q256JVEQ and 25Q80DV1G...Which chip needs to be read/backed up/edited/reflashed?
                          • Vesko356
                            VIP Moderator
                            • Aug 2018
                            • 4386
                            • Bulgaria 🇧🇬
                            "Do not touch the 25Q80xxxx chip"
                            25Q256JVEQ is your bios chip.
                            Also read post #7 - find the second one.
                            Become a Badcaps supporter
                            Thanks to all supporters.
                            • patcopley1
                              • Jun 2021
                              • 11
                              I don't see any other SOP8/SOIC8 chips...Could it perhaps be on the reverse side of the motherboard?
                              • Vesko356
                                VIP Moderator
                                • Aug 2018
                                • 4386
                                • Bulgaria 🇧🇬
                                Yes.
                                • patcopley1
                                  • Jun 2021
                                  • 11
                                  Yes.
                                  Thank you...Before I remove the motherboard, I wanted to read the 256 chip and save the bin file...Everything seems to go smoothly...I create 2 backups and compare in HexCamp, however the two files are not even close...I tried a few times and am getting the same result...Tried with NeoProgrammer and ASProgrammer. I am using a USB CH341A (black board) w/a Pomona 5250 clip...Any suggestions for a good reading? I removed the battery first...I connected the clip to the chip, inserted the USB, started the software...I have tried rearranging the placement on the chip, but no joy..
                                  I also have a TL866II, but I can't get that to read anything at all...it's also my understanding those are mostly used with the desoldered chip in a socket adapter rather than a clip...
                                  How do you suggest I proceed?
                                  • patcopley1
                                    • Jun 2021
                                    • 11
                                    OK I fixed the chip reading issue...
                                    I found a chip opposite of the main chip...it's an (ISSI) IC25LP128
                                    dump attached
                                    • Vesko356
                                      VIP Moderator
                                      • Aug 2018
                                      • 4386
                                      • Bulgaria 🇧🇬
                                      I am using a USB CH341A (black board) w/a Pomona 5250 clip...Any suggestions for a good reading?...
                                      ...How do you suggest I proceed?
                                      Reading the chip in circuit (especially with the clamp) is always a bad idea - unsolder the chip and don't use a clip. Make at least 3 dumps and compare them to be sure you have a good backup (to avoid a big headache later).
                                      Besides using a SOIC-8 clip to read a WSON-8 chip is (almost) impossible.
                                      Don't think so.
                                      Look at the archive - it's 192 Bytes because it's empty, full of FF's.
                                      • patcopley1
                                        • Jun 2021
                                        • 11
                                        I finally desoldered the chip and put it in a socket reader...
                                          HP EliteBook EliteBook x360 1040 G5 Notebook PC Notebook 1000 Specification for Upgrade or Repair
                                          This specification for the HP EliteBook EliteBook x360 1040 G5 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook x360 1040 G5 Notebook PC boardview and EliteBook x360 1040 G5 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
                                          09-06-2024, 09:53 AM
                                          09-06-2024, 07:20 AM
                                          HP EliteBook x360 1040 G9 Hybrid (2-in-1) Specification for Upgrade or Repair
                                          This specification for the HP EliteBook x360 1040 G9 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1040 G9 boardview and 1040 G9 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
                                          09-07-2024, 05:20 AM
