BIOS Unlock For Dell Latitude 5330
  • hyditech
    • 272
    • nigeria
    I have dell 5330 11th Gen with password...
    board number is 203101
    S/N JZ0RSL3
    • volinakis
      • Jan 2021
      • 2603
      • N/A
      S/N JZ0RSL3
      try
      • hyditech
        • 272
        • nigeria
        Originally posted by volinakis
        try
        THANK YOU SO MUCH.... PASSWORD CLEARED
        • volinakis
          volinakis commented
          Editing a comment
          you are welcome.
      • skavioce
        • May 2015
        • 32
        • morocco
        hi you kan remove password from to bin latitude 5330
        • hoaca388
          hoaca388 commented
          Editing a comment
          your service card
        • skavioce
          skavioce commented
          Editing a comment
          st D100HS3
      • skavioce
        • May 2015
        • 32
        • morocco
        st D100HS3
        • hoaca388
          • Jan 2022
          • 11114
          • Viet Nam
          #26
          Originally posted by skavioce
          st D100HS3
          Unlocked
          Become a Badcaps supporter
          Thanks to all supporters.
          • skavioce
            skavioce commented
            Editing a comment
            THINK YOU WORK FINE
        • IDElectroRep
          • Dec 2020
          • 10
          • United Kingdom
          #27
          • mac2sell
            • Aug 2017
            • 64
            • Italy
            #28
            Please helpme with Dell Latitude 5410 Bios Password
            ST:4RQ2HX3
            • rex98
              • Feb 2023
              • 1234
              • Mandaue CEBU, Philippines
              #29
              ST:4RQ2HX3
              1st boot, press F2, write service tag, disable Absolute, save (Apply changes), restart. 2nd boot press Alt+F to exit manufacturing mode
              • mac2sell
                • Aug 2017
                • 64
                • Italy
                #30
                Working fine, thank you very much
                • sergiogl95
                  • Jun 2023
                  • 3
                  • Santiago
                  #31
                  Hello, friends, I hope you can help me..... I have a Dell Latitude 5330 that without realizing it and because of those things in life I did something wrong, I deleted the data from the 25Q80 Chip (8MB) the other 16mb and 32mb chips do have them but the notebook is totally dead and has not done anything since Delete those files, I hope you understand me and can help me, thank you friends.​
                  • robin.office
                    • Jun 2024
                    • 7
                    • Singapore
                    #32
                    Hello BIOS gurus,
                    I have DELL Latitude 5330 (S/T:12CYXL3, motherboard model: Southpeak 4DJ9K$LA 203101-1)) and would like to unlock the BIOS admin and remove any trackers e.g. Absolute or CompuTrace.
                    I have taken the backup of W25Q256JV chip using CH341A programmer. Please see attached the bin file. Could someone help unlocking this attached file.
                    Thanks,
                    PS: I am hoping that this is the chip that contains the BIOS? because there is another chip W25R128JV that sits close to this chip but I am not sure if that needs to be re-flashed?
                  • robin.office
                    • Jun 2024
                    • 7
                    • Singapore
                    #33
                    Have updated the post. thanks.
                    • volinakis
                      • Jan 2021
                      • 2603
                      • N/A
                      #34
                      here. let it run for 2 mins, it will restart several times with no image. 1st boot press F2, write serial, disable Absolute, save (Aplly Changes), 2nd boot press alt+F to exit factory mode.
                      • robin.office
                        • Jun 2024
                        • 7
                        • Singapore
                        #35
                        Thank you friend for your prompt response. I flashed that file but unfortunately the laptop doesn't start, when I press the power button, the white Power light comes on the button for 30 seconds and goes off. There is no display, no fan, no keyboard light, nothing happening on the laptop. I did the following:
                        (1) Prior to flashing the file, I removed the battery and CMOS battery connections both.
                        (2) Flashed the file and verified that the file was correctly verified.
                        ​​​​​​(3) Connected the CMOS battery, and pressed the power button for about 30 seconds prior to connecting the laptop battery.
                        (4) Pressed the Power button after connecting the laptop battery.
                        (5) White light on power button comes on for about 30 seconds and goes off.
                        Any ideas? Are there any chances that the file that I read originally might be corrupted and therefore the unlocked file is also corrupted? Or the unlocked file is just a generic one?
                        • robin.office
                          • Jun 2024
                          • 7
                          • Singapore
                          #36
                          Anyone? Please help 🙏
                          • volinakis
                            • Jan 2021
                            • 2603
                            • N/A
                            #37
                            check soldering. Put back original bios and see if it starts, if not, you didn't read properly bios chipset.
                            • robin.office
                              • Jun 2024
                              • 7
                              • Singapore
                              #38
                              Ok I will try flashing the original BIOS file and see if that works. In case it doesn't, do we have a generic BIOS file for this model?
                              I didn't desolder the chip, I used WSON8 pogo pin probe to read and write it.
                              Thanks.
                              • robin.office
                                • Jun 2024
                                • 7
                                • Singapore
                                #39
                                I flashed the original backup file and the laptop doesn't start, so I am convinced that my backup file was corrupted. Can anyone help with repairing the file? Or is there a universal BIOS bin file that I can flash? What options do I have, if any
                                • bhatti76
                                  • Jun 2014
                                  • 7
                                  • australia
                                  #40
                                  please need help to unlock Dell Latitude 5330 bios password
                                  • peste
                                    peste commented
                                    Editing a comment
                                    post Service Tag and the motherboard model.
