New Members
Please consider donating to this site if it has helped you. We rely on these donations.
Please also introduce yourself here Introduce yourself here.
And finally, Read the Forum rules here.
Hi, please help me remove computrace. I did try with RcUnlocker on 16Mb eeprom and no result, absolute is still active and can not be modified, i think 32Mb has to be modified.
Thank you.
Thank you.
thank you. it was fun, with your bios it made some kind of bios update, then enter in MPM mode with absolute disabled, i didn't save serial, UUID, sku, etc so i put back old bios, saved datas and when i put back your bios I had all datas back, absolute disabled and no MPM.
Hi, I have Dell precision 5540 laptop from old workplace,decommissioned old stock. its a good spec laptop i9-9880H etc, so I decided to keep it and use it for personal purposes.
I was checking bios settings and I found that Absolute (Computrace) is permanently enabled/activated, and field is grayed out, unable to change it to disabled/deactivated state. The laptop status is clean, absolute has no any warnings or messages booting pre-bios pre-OS or post booting, while using laptop, im just not feeling safe having absolute permanently enabled having backdoor on a bios level enabled to my...
I have a DELL Latitude 5520 that is locked when i go into Windows. It says device freeze, I can still use it under Linux without any issue.
I have access to the BIOS but the 'disable Absolute" is greyed out ant i cant do nothing
