Acer C773 chrome device lock by administrator any solutions?
  • salim5566
    • Jul 2022
    • 19
    • New Zealand
    Hi guys i have acer chrome c773 disable and sn i think lock i have try to with RC unlocker with unlock bin still same this what is showing when you turn on laptop.
    anyway i an just change few number of SN and it cud work?
  • salim5566
    • Jul 2022
    • 19
    • New Zealand
    Re: Acer C773 chrome device lock by administrator any solutions?
    Hi any solutions for this?
    • Mazorca
      • Jan 2017
      • 463
      Did you go into dev mode then download the entire os specific to your chrome and re-install it?
      • salim5566
        • Jul 2022
        • 19
        • New Zealand
        not allow developer mode lock
        • Mazorca
          • Jan 2017
          • 463
          Look at your original BIOS in hex editor, both dev mode and enrollment should be flagged with 1. Compare to unlocked by RCUnlocker, should be flagged with 0. Usually that is it, no further messing with it. Press ESC key and the refresh (with the circle) together so it will take you to dev mode.
          • salim5566
            • Jul 2022
            • 19
            • New Zealand
            Thanks for your detail reply really Appreciated
            can you tell me on hex editor how to i find enrollment and dev mode so i can check?
            • Mazorca
              • Jan 2017
              • 463
              Open original bin in hex editor. Type "enrollment" without quotes in Search tab >Find, and in Datatype: text only. That will take you where enrollment shows up and just a bit before is dev mode. You should see both are flagged as 1. Highlight each 1, and type over it 0. Do both, they will be in red on the hex block field and show as 30. Save as new file, name it and that is it, you got yourself an unlocked chrome bin. RCUnlocker does this automatically. Reflash chip, go to dev mode and install operating system.
              • salim5566
                • Jul 2022
                • 19
                • New Zealand
                Thanks for the help very helpful
