Dell Inspiron 3501 bios
  • tecnico garantias
    • Mar 2018
    • 17
    • el salvador
    #101
    I need help Dell laptop gives TMP error
    LA-K034P
    SERVICE TAG 2K26HJ3
    • shiyab
      • Sep 2023
      • 1373
      • india
      #102
      LA-K034P
      SERVICE TAG 2K26HJ3
      post both file
      • tecnico garantias
        • Mar 2018
        • 17
        • el salvador
        #103
        Originally posted by shiyab
        publicar ambos archivos
        BOTH FILES ARE IN THE RAR
        • shiyab
          • Sep 2023
          • 1373
          • india
          #104
          HI try
          • tecnico garantias
            • Mar 2018
            • 17
            • el salvador
            #105
            HI try
            Tanks.
            In BIOS, TPM is enabled but it disables itself
            TPM error still appears and there is no audio​
            • shamaltech
              • May 2023
              • 102
              • Sri Lanka
              #106
              Originally posted by hoaca388
              Inspiron 3501 , Service Tag: 8CXJSD3
              Can you fix this bios?
              Laptop won't turn on.
              Nothing happens when press power button.
              Power light is On.
              3V/5V is ok.
              GDI5A LA-K036P REV 1.0
              ST:76TS3G3​
              • rex98
                • Feb 2023
                • 1273
                • Mandaue CEBU, Philippines
                #107
                Power light is On.
                3V/5V is ok.
                ST:76TS3G3​
                flash both
                • shamaltech
                  • May 2023
                  • 102
                  • Sri Lanka
                  #108
                  Originally posted by rex98
                  flash both
                  I tried but still same problem.
                  Power light is On.
                  3V/5V is ok.​
                  There are two 1.8V present.
                  No ram voltage.
                  Any other solution
                  • rex98
                    • Feb 2023
                    • 1273
                    #109
                    Power light is On.
                    3V/5V is ok.​
                    No ram voltage.
                    Any other solution
                    board code?
                    • shamaltech
                      • May 2023
                      • 102
                      • Sri Lanka
                      #110
                      board code?
                      LA-K036P Rev 1.0
                      • MayuraPerera
                        • Jul 2024
                        • 4
                        • Sri Lanka
                        #111
                        Dell Inspiron 3501 not working (no display, power light white for 4 sec and off). I tried flashing a Stock Bios and is worked from Manufacturing mode. And I tried Alt+F and is till looping for that mode. i attaching the main bios file. pls fix.. (SERVICE TAG : 74KCLF3 )
                        • shiyab
                          • Sep 2023
                          • 1373
                          • india
                          #112
                          post dumb
                          • MayuraPerera
                            • Jul 2024
                            • 4
                            • Sri Lanka
                            #113
                            post dumb
                            What information do you need?
                            • shiyab
                              • Sep 2023
                              • 1373
                              • india
                              #114
                              post bord no
                              • MayuraPerera
                                • Jul 2024
                                • 4
                                • Sri Lanka
                                #115
                                • shiyab
                                  • Sep 2023
                                  • 1373
                                  • india
                                  #116
                                  flash both file and feedback
                                  • MayuraPerera
                                    • Jul 2024
                                    • 4
                                    • Sri Lanka
                                    #117
                                    When clicking power button. Orange led turn on as long as i hold the power button
                                    • adamaro
                                      • Sep 2013
                                      • 3
                                      • prato
                                      #118
                                      LA-K032P
                                      SERVICE TAG HX7LSD3
                                      Express service code: 39013457367
                                      Inspiron 3501
                                      Attached Bios Dump
                                      Thanks in advance
                                      Federico
                                      • hoaca388
                                        Badcaps
                                        • Jan 2022
                                        • 11702
                                        #119
                                        LA-K032P
                                        SERVICE TAG HX7LSD3
                                        Inspiron 3501
                                        Attached Bios Dump
                                        Thanks in advance
                                        Federico
                                        Try
                                        • adamaro
                                          • Sep 2013
                                          • 3
                                          • prato
                                          #120
                                          Unfortunately, it doesn't work.
                                          What can I do?
                                          Federico
                                            DELL Inspiron 3501 Notebook 3000 Specification for Upgrade or Repair
                                            This specification for the DELL Inspiron 3501 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 3501 boardview and 3501 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Inspiron 3501...
                                            09-07-2024, 02:50 AM
                                            09-07-2024, 02:20 AM
                                            09-07-2024, 02:00 AM
