Dell Inspiron 3501 bios
    I need help Dell laptop gives TMP error
    LA-K034P
    SERVICE TAG 2K26HJ3
      LA-K034P
      SERVICE TAG 2K26HJ3
      post both file
        Originally posted by shiyab View Post
        publicar ambos archivos
        BOTH FILES ARE IN THE RAR
          HI try
            HI try
            Tanks.
            In BIOS, TPM is enabled but it disables itself
            TPM error still appears and there is no audio
              Originally posted by hoaca388 View Post
              Inspiron 3501 , Service Tag: 8CXJSD3
              Can you fix this bios?
              Laptop won't turn on.
              Nothing happens when press power button.
              Power light is On.
              3V/5V is ok.
              GDI5A LA-K036P REV 1.0
              ST:76TS3G3
                Power light is On.
                3V/5V is ok.
                ST:76TS3G3
                flash both
                  Originally posted by rex98 View Post
                  flash both
                  I tried but still same problem.
                  Power light is On.
                  3V/5V is ok.
                  There are two 1.8V present.
                  No ram voltage.
                  Any other solution
                    Power light is On.
                    3V/5V is ok.
                    No ram voltage.
                    Any other solution
                    board code?
                      board code?
                      LA-K036P Rev 1.0
                        Dell Inspiron 3501 not working (no display, power light white for 4 sec and off). I tried flashing a Stock Bios and is worked from Manufacturing mode. And I tried Alt+F and is till looping for that mode. i attaching the main bios file. pls fix.. (SERVICE TAG : 74KCLF3 )
                          post dumb
                            post dumb
                            What information do you need?
                              post bord no
                                  flash both file and feedback
                                    When clicking power button. Orange led turn on as long as i hold the power button
                                      LA-K032P
                                      SERVICE TAG HX7LSD3
                                      Express service code: 39013457367
                                      Inspiron 3501
                                      Attached Bios Dump
                                      Thanks in advance
                                      Federico
                                        LA-K032P
                                        SERVICE TAG HX7LSD3
                                        Inspiron 3501
                                        Attached Bios Dump
                                        Thanks in advance
                                        Federico
                                        Try
                                        Become a Badcaps supporter
                                        Thanks to all supporters.
                                          Unfortunately, it doesn't work.
                                          What can I do?
                                          Federico
