Lenovo T14s (intel-NM-C891) Low wattage on any charger - Needed tb ic image
  • CornholioGSM
    • Feb 2014
    • 265
    • CZECH
    Hello hello,
    i have here T14s with charging problem - low wattage detected on any charger, it wont charge when laptop is on...show charging but not charging.
    For me it looks like problem with thunderbolt firmware stored inside U5502 (MX25L80) because laptop is bios locked and u5502 looks soldered...maybe someone means, that it is bios for unlock it with patch method.
    So first will be maybe good to test flash good thinderbolt firmware.
    Anyone have image ?
    It is T14s, intel 10gen,GT4A3/GX3A2 NM-C891.
    Attached image if ic...for me looks like filled only with zeros
  • CornholioGSM
    • Feb 2014
    • 265
    • CZECH
    Re: Lenovo T14s (intel-NM-C891) Low wattage on any charger - Needed tb ic image
    BTW...how about test to flash thunderboard from another model - T14?...same intel generation
    • CornholioGSM
      • Feb 2014
      • 265
      • CZECH
      Problem solved
      I have flashed tbt spi with zeros (not sure it was needed) - labtop booted into win but not charging message still and no tbt in device manager.
      Downloaded tbt firmware update doesnt work because tbt was not detected.
      Soo update was extracted and TBT.BIN was flashed to spi.
      Rebooted but still same.
      Then i have disconnected all batteries and press rst button on mobo for few seconds.
      Reconnected batteries,connected charger and power on...charging led makes purple flashing and power led / keyboard baclight flashes soo.
      This flashing and rebooting takes maybe 30 seconds - I thought the laptop is dead.
      ...and finally voila laptop boots without charger wattage error. Windows have detected thunderbolt in device manager , firmware version is visible and battery charges without problem
        • 22279
        • longtuoc
          • Apr 2016
          • 5
          • Viet Nam
          Backup from to machine working
          • longtuoc
            • Apr 2016
            • 5
            • Viet Nam
            • CornholioGSM
              • Feb 2014
              • 265
              • CZECH
              not needed baut thank you...problem was solved
              • longtuoc
                • Apr 2016
                • 5
                • Viet Nam
                U2101 if you need
                • Oliver111
                  • Jul 2018
                  • 52
                  • Kiev
                  Problem solved
                  Yoga 3rd gen. Your solution works! Thank you sir!
                  • motormayhem
                    Lenovo T460 Only Charges on One Charger
                    by motormayhem
                    Laptop Question
                    I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
                    A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
                    05-12-2023, 01:46 PM
                  • mountainman1900
                    Dell XPS 5920 Clean BIOS image needed for CH341A Flashing
                    by mountainman1900
                    My Dell XPS 15 5920 randomly stopped working with 3 amber and 5 white flashes, stuck on Dell logo. USB BIOS flash did not initiate; nor F buttons nor CTRL + Esc do anything. I believe flashing with CH341A is my only option at this point. I am looking for a clean working BIOS image. Service tag is CMQXRV3.
                    Thank you!
                    Today, 07:00 AM
                    HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
                    This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                    09-12-2024, 02:20 PM
                    NVDC charger configuration...
                    11-05-2024, 03:28 PM
                  • Jaime Morillo
                    Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
                    by Jaime Morillo
                    Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
                    The TV was stuck on the logo and I couldn't access the update menu.
                    I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
                    The image result was good, but the image is inverted.
                    The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
                    Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
                    08-18-2025, 11:38 AM
