ACER NITRO 5 AN515-53 (DH5VF LA-F952P rev: 1.0N)
  • vienzen
    • Feb 2015
    • 112
    • PHILIPPINES
    Problem: No display
    bios backup file
  • hoaca388
    Badcaps
    • Jan 2022
    • 12118
    Re: ACER NITRO 5 AN515-53 (DH5VF LA-F952P rev: 1.0N)
    Originally posted by vienzen
    acer nitro 5 an515-53
    dh5vf la-f952p rev: 1.0n
    problem: No display
    bios backup file
    • exerion5000
      • Aug 2014
      • 83
      • Argentina
      Acer Nitro An515-53-55g9 Bios DH5VF LA-F952P Rev 1.0N
      Hi, need bios for Acer Nitro An515-53-55g9 Bios DH5VF LA-F952P Rev 1.0 N
      Original bios with no display Attached
      Thanks in advance!
        • 21457
        Re: Acer Nitro An515-53-55g9 Bios DH5VF LA-F952P Rev 1.0N
        Thanks in advance!
        laptop serial number ?
        • exerion5000
          • Aug 2014
          • 83
          • Argentina
          S/N NHQ3YAA00191003ACE3400
          Thank you
          • hardware1
            • Sep 2021
            • 2943
            • N/A
            Thank you
            One of those should works, it's a virgin bios image from Acer with your DMI.
            all donations are welcome,
            • exerion5000
              • Aug 2014
              • 83
              • Argentina
              Thank you very much, I will try and comment.
                • 21457
                It should be the 2nd one, the motherboard is Rev 1.0 DH53F_10
                • hardware1
                  • Sep 2021
                  • 2943
                  • N/A
                  I have searched for the motherboard and didn't find (DH53F_10) neither (DH53f_1A). Are you pointing to the (Rev 1.0N)?
                    • 21457
                    Heres the 2v motherboard revisions, i don`t know what the N means.
                    rev 1.0 https://www.aliexpress.com/item/1005004079512598.html Bios version DH53F_10
                    rev 1A https://www.aliexpress.com/item/1005003386521303.html Bios version DH53F_1A
                    • hardware1
                      • Sep 2021
                      • 2943
                      • N/A
                      Got it, thanks.
                      • Arador
                        • Jun 2025
                        • 9
                        Acer Nitro 5 AN515-53 powers on, and starts to POST, but it cannot read any attached drive (NVMe or SATA), and internal keyboard/mouse not functioning.
                        I get power through the USB ports, but no data, so external device do not work either.
                        I am hoping that it is a semi-corrupted BIOS, is there a clean one available I can try? Will the 52 BIOS work on a 53?
                        SN: NBQ3M11002815A52113400
                        • peste
                          • Dec 2016
                          • 13199
                          • ROMANIA
                          post the contents of the bios chip even if it is corrupted.
                          • Arador
                            • Jun 2025
                            • 9
                            Here it is. And I was wrong on the Serial Number; I got it off the board not the case. Here is the serial number from the case
                            SN: NHQ3ZAA001816042023400
                            Also, I got the exe BIOS files from Acer and used the TEMP folder method to extract the bin files, but they are too large for the chip and I can't find out how to shrink to the correct size.
                            • Arador
                              • Jun 2025
                              • 9
                              Never mind, I found the correct bin files above. Thank you for assisting me.
