Ga-rx5lyc bios dump
  • nissimezra
    • 178
    Ga-rx5lyc bios dump
    Hi all
    need dump file for a laptop motherboard GA-RX5LYC REV 2
    Thanks in advanced
    • 22279
    Re: Ga-rx5lyc bios dump
    Originally posted by nissimezra
    Hi all
    Thanks in advanced
    Whats the full laptop model number. Have you looked at the gigabyte support page for the bios and EC
    • nissimezra
      • 178
      Thanks for reply
      the model is AORUS 15G YC
      https://www.gigabyte.com/Laptop/AORU...upport-dl-bios
      s/n: SN21080J000006
      Can I download the bios from the website and program it?
      • nissimezra
        • 178
        I extracted the ROM from the installer but its only 16mb the bios is 32mb
        • hoaca388
          Badcaps
          • Jan 2022
          • 12441
          Your file has only the first 16MB of bios data, the last 16MB with 00 bits inserted
          ​https://www.badcaps.net/donate
          • nissimezra
            • 178
            thank you for your help
            To program this file you attached?
              • 22279
              Flash it and see what happens. Its strange that its got 16MB of padding after the bios, but the VSCC table does have support for 16MB and 32MB chips
              • nissimezra
                • 178
                Thank you both for your help.
                I'll post back
                • nissimezra
                  • 178
                  Thx for your help
                  There is no vcore and gpu voltage. it was shot in the dark to try bios.
                  Thanks to both of you
                    • 22279
                    I'll post back
                    Its not clear how the updater would write to the 32MB chip,if the 16MB padding at the end is intentional,and if it would work that way.The updater might split the bios and write some padding inbetween ? ,don`t know.
                    Try it again,this time with a 16MB Macronix chip.The chip ID in the VSCC table is C22018.Theres a number of different ones with the same ID
                    MX25L12805D id="C22018" page="256" size="16777216"
                    MX25L12835E id="C22018" page="256" size="16777216"
                    MX25L12835F id="C22018" page="256" size="16777216"
                    MX25L12836E id="C22018" page="256" size="16777216"
                    MX25L12839F id="C22018" page="256" size="16777216"
                    MX25L12845E id="C22018" page="256" size="16777216"
                    MX25L12845G id="C22018" page="256" size="16777216"
                    MX25L12845F id="C22018" page="256" size="16777216"
                    MX25L12865E id="C22018" page="256" size="16777216"
                    MX25L12865F id="C22018" page="256" size="16777216"
                    MX25L12873F id="C22018" page="256" size="16777216"
                    MX25L12875F id="C22018" page="256" size="16777216"
                    • nissimezra
                      • 178
                      Thank you my friend the customer took the laptop. I don't think it's a bios problem because no voltage on the gpu and cpu.
                      • Citymin
                        by Citymin
                        S/N : 5RNK9FFT70...
                        08-05-2025, 05:12 AM
                      • bondminer009
                        Need Bios for Latitude 7650 (No Original / dump bios file)
                        by bondminer009
                        Good Evening,
                        Need help, is there any possible to get the bios file? Because received from my team without any dump file / original bios file
                        Thank You
                        Salam,
                        Three
                        11-12-2024, 07:48 AM
                      • picouser
                        Looking for HP Envy Laptop 17-cw1003ca (A00XQUA) BIOS dump file
                        by picouser
                        Power off when the laptop is doing a BIOS update. The file seems corrupted, or the DMI data was written in the wrong place. Could someone help me with it? I uploaded the backup file from the BIOS chip and the generic file extracted from the HP website. Thanks!...
                        11-24-2025, 10:31 PM
                      • adelage
                        Merge ECS Z77-H2 bios cap file with original dump
                        by adelage
                        I am trying to recover an ECS Z77-H2 motherboard, I dumped the original bios with a ch341a programmer, the bios from the manufacturer is a .cap file of smaller size, and it seems that I need to merge this file with other information from the dump, anyone can explain how to do that?
                        03-11-2025, 03:07 AM
                      • joshAU
                        BIOS file for N550JK (original dump attached)
                        by joshAU
                        Hi all.
                        I'm looking for a BIOS file for an Asus N550JK.
                        I have a Asus R552J, which I believe is identical to the Asus N550JK.
                        I downloaded the latest BIOS (210) for the R552.
                        It is named N550JKAS.210.
                        The BIOS file is however only 6mb in size.
                        I've read the chip with a CH341A programmer and verified the file.
                        That file is actually 8mb in size.
                        I'm wanting to remove the BIOS password from this unit.
                        It prompts you to input the password when turned on, so its sort of behaving like a power on password rather than...
                        08-09-2022, 08:06 PM
