Lenovo ideapad 5-14alc05
  • dimis7
    • Feb 2011
    • 20
    Re: Lenovo ideapad 5 14alc05
    Originally posted by Frostya
    Sorry, guys.
    Board has short circuit in 1,8 power line.
    It's not a bios.
    One of the indutor became too hot. It has strange voltage: 0,846 from one side and 0,766 from other.
    Heat pipes hot too.
    Your BIOS chip is probably 1.8v device.
    Did you use an adaptor to read it?
    Like this one.
    If not maybe you burn it with CH341A programmer... Or even worse you burn something else in the same rail...
    BTW i fixed mine. It was a shorted cap + shorted audio codec chip.
    The BIOS in post #22 is working.
    • Frostya
      • Sep 2023
      • 4
      • Armenia
      Yes my chip is 1,8v device, and i have the adapter for it.
      The indutor was hot before i have tried to read the BIOS. So i'm sure, that it was broken before me.
      Last two night before dead, lenovo drain all battery till night. Short circuit progressed to total.
      • dimis7
        • Feb 2011
        • 20
        Sorry, guys.
        It's not a bios.
        Heat pipes hot too.
        According to service manual (link here) the PL602 is on 0.75V ALWP rail and not on 1.8V rail, so your problem in not there...
        • Frostya
          • Sep 2023
          • 4
          • Armenia
          Thank you for advice.
          Will look at the board more carefully.
          Power pin of bios has only 0.028 of 1.8, and look like almost shorted to the ground.
          Wiil try to find power supply for 1.8 at board to check it health.
          Thank again for manual!
          • giorgiodi
            • Nov 2023
            • 3
            • Sicilia
            Good morning guys, I have this Lenovo ideapad flex 5 14alc05 laptop, the problem seems to be the bios, I would like to reprogram it, this could be fine
            https://www.amazon.it/TECNOIOT-CH341...zcF9hdGY&psc=1
            in the bios I attach the photo it says
            winbond
            74m12jws10
            2115,
            this is it okay? There it says 24 25 Series EEPROM Flash can you give me some clarification?
            • peste
              • Dec 2016
              • 12329
              • ROMANIA
              #26
              winbond
              74m12jws10
              2115,
              look at the board (on both sides).. do you have another bios chip??
              • giorgiodi
                • Nov 2023
                • 3
                • Sicilia
                #27
                Hi, I completely disassembled the mobo, there is nothing behind it, just this as a bios chip
                • dimis7
                  • Feb 2011
                  • 20
                  #28
                  winbond
                  74m12jws10
                  2115,
                  Hi! This programmer should be compatible with your BIOS chip but you also need the 1.8v adapter / converter or you risking damaging your chip!
                  https://www.amazon.it/GeKLok-CH341A-...27&sr=1-3&th=1
                  From the service manual the chip is the same as Winbond W25Q128 and software for this programmer is compatible with this chip.
                  I read / write mine in circuit using the SOIC8 / SOP8 clip.
                  • onwork
                    • Jul 2024
                    • 3
                    • Франция
                    #29
                    Hello everyone. I need a bios for Lenovo ideapad 5 14ALC05
                    There was a problem with a black screen; all the symptoms pointed to a problem with the BIOS firmware. One firmware from the forum (like post number 2) helped and the computer turned on But now it asks for a password. Unfortunately, the old BIOS firmware was not saved..
                    Sn R912XTAM
                    MTM 82HU00AYFR
                    MO R(N0B1525009
                    LC56-14A SVT 203021-1
                    448.0md08.0011​
                    thank you in advance
                    • onwork
                      • Jul 2024
                      • 3
                      • Франция
                      #30
                      Please help me fix the BIOS. After flashing the firmware, the computer turned on and after rebooting the capslock and esc buttons are lit. Notebook Flex 5-14ALC05 Laptop (AMD)(ideapad) - Type 82HU ,s/n R912XTAM ,MTM 82HU00AYFR
                      LC56-14A SVT 203021-1 448.0MD08.011 MO R9N0B1525009 Unfortunately, the old firmware was not saved( Thanks in advance​
                      • kalilinux25
                        • Mar 2018
                        • 2069
                        • ZAMBOANGA SIBUGAY
                        #31
                        please try freshh no dmi
                        • onwork
                          • Jul 2024
                          • 3
                          • Франция
                          #32
                          unfortunately it didn’t work. there is no reaction now
                          • kalilinux25
                            • Mar 2018
                            • 2069
                            • ZAMBOANGA SIBUGAY
                            #33
                            Maybe you have other issue not bios
                            • Lukosiukas
                              • Jul 2018
                              • 106
                              • Lithuania
                              #34
                              Good day, im insearch of help. Could someone verify or rebuild bios ?
                              Lenovo ideapad 5 15are05
                              FLMA0 LA-J701P
                              REV 1.0
                              SN MP1SKQ37
                              MTM 81YM008WLT
                                • 20441
                                FLMA0 LA-J701P
                                REV 1.0
                                SN MP1SKQ37
                                MTM 81YM008WLT
                                No, not in this thread, it`s for the 5-14alc05 as it says in the thread title. Use the forum search engine to find a 5-15are05 thread and post there....
                                • elniñodelcautin
                                  • Jul 2023
                                  • 14
                                  • bogota
                                  #36
                                  I need to change the EC (NPCE386PB0DX-GP) because it is shorted. Does anyone know if it is programmed or is it programmed only with the bios? Since I couldn't find any file for the EC, please help
                                    • 20441
                                    It might have an external eeprom chip, https://www.badcaps.net/forum/troubl...64#post3515964 , in the schematic for that board is has an NPCE386PB0BX
                                    • nisham
                                      • Mar 2018
                                      • 7
                                      • India
                                      #38
                                      ideapad FLMA0 LA-J701P
                                      S/N MP27F9HX
                                      NO DISPLAY
                                      HELP PLEAE
                                      • peste
                                        peste commented
                                        Editing a comment
                                        don't post pictures unless asked....
                                    • Dacmen88
                                      • Mar 2022
                                      • Srbija
                                      #39
                                      Hello all. Can anybody help me with finding .bin for thi mb but 3.0 revision.
                                        SMDFlea commented
                                        Editing a comment
                                        The bios is the same regardless of the motherboard revision.
                                    • hoaca388
                                      Badcaps
                                      • Jan 2022
                                      • 11377
                                      • Viet Nam
                                      #40
                                      S/N MP27F9HX
                                      NO DISPLAY
                                      HELP PLEAE
                                      ideapad 5-14ALC05 Laptop - Type 82LM
                                        Lenovo IdeaPad IdeaPad 3 15IGL05 Notebook 3 Specification for Upgrade or Repair
                                        This specification for the Lenovo IdeaPad IdeaPad 3 15IGL05 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 3 15IGL05 boardview and IdeaPad 3 15IGL05 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                        09-07-2024, 05:20 AM
                                        Lenovo IdeaPad IdeaPad 3 17ITL6 Notebook 3 Specification for Upgrade or Repair
                                        This specification for the Lenovo IdeaPad IdeaPad 3 17ITL6 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 3 17ITL6 boardview and IdeaPad 3 17ITL6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                        Lenovo IdeaPad IdeaPad Gaming 3 15IHU6 Ultrabook 3 Specification for Upgrade or Repair
                                        This specification for the Lenovo IdeaPad IdeaPad Gaming 3 15IHU6 Ultrabook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad Gaming 3 15IHU6 boardview and IdeaPad Gaming 3 15IHU6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
                                        Lenovo IdeaPad IdeaPad Gaming 3 15ACH6 Notebook 3 Specification for Upgrade or Repair
                                        This specification for the Lenovo IdeaPad IdeaPad Gaming 3 15ACH6 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad Gaming 3 15ACH6 boardview and IdeaPad Gaming 3 15ACH6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                        09-07-2024, 05:00 AM
                                        Lenovo IdeaPad IdeaPad 1 14IJL7 Notebook 1 Specification for Upgrade or Repair
                                        This specification for the Lenovo IdeaPad IdeaPad 1 14IJL7 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 1 14IJL7 boardview and IdeaPad 1 14IJL7 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
