Surface Laptop 3 Model 1868 Bios password
  • ajbernasko
    • Mar 2022
    • 229
    • ghana
    #81
    Re: Surface Laptop 3 Model 1868 Bios password
    @PESTE your previous offsets for unlocking works. Thank you very much. I was missing some details as to the re-programming should be 1.8V
    • ajbernasko
      • Mar 2022
      • 229
      • ghana
      #82
      Hello @peste, the touch does not work. Also is there a way I could have the serial number written back to the surface ?
      • ajbernasko
        • Mar 2022
        • 229
        • ghana
        #83
        Hello, in this file customer computer has no bios lock however it is locked to management. I tied many unlocked dumps from this post and I got touch firmaware 0.00.00, loading windows from usb disables keyboard and trackpad as well
        • Gsa_rider67
          • Apr 2023
          • 5
          • FRANCE
          #84
          Hy I have sufrace laptop 3 model 1868. the Bios is blocked by a password that I do not have.
          I have windows 11 functional and started
          Help me please. Im a noobs sorry.
            VIP Moderator
            • Aug 2018
            • 4386
            • Bulgaria 🇧🇬
            #85
            BIOS guides, methods, resources and tools
            Password removal by laptop brand
            Originally posted by AAAC
            @thatguycalledrob
            With the MS Surface Pro 3 and others the password can be recovered, so is sufficient to just obtain a partial BIOS dump using a software utility, then the password is recovered.
            For a MS Surface Laptop 3 you need to obtain a Full BIOS reading using a BIOS chip programmer, then the BIOS file is patched and this new file is programmed back to chip.
            As for the fptw64.exe utility don’t don’t if it has WRITE rights to the chip, otherwise it may work.
            Become a Badcaps supporter
            Thanks to all supporters.​
            • Gsa_rider67
              • Apr 2023
              • 5
              • FRANCE
              #86
              thank you for your reply.
              Is there a way not to unsolder the chip? where is it placed on the motherboard?
                VIP Moderator
                • Aug 2018
                • 4386
                • Bulgaria 🇧🇬
                #87
                Why don't you read the thread from the beginning? Many of the questions are already answered.
                There is information about your question at post 74 & 75 , regarding the ways to unsolder the chip, you can use hot air station, or WSON8 pogo pin adapter, or solder wires from the programmers adapter board to the chip legs, or wires soldered to surrounding parts connected to the traces.
                • Gsa_rider67
                  • Apr 2023
                  • 5
                  • FRANCE
                  #88
                  There is information about your question at post #74 & #75 , regarding the ways to unsolder the chip, you can use hot air station, or WSON8 pogo pin adapter, or solder wires from the programmers adapter board to the chip legs, or wires soldered to surrounding parts connected to the traces.
                  i buy this?
                    VIP Moderator
                    • Aug 2018
                    • 4386
                    • Bulgaria 🇧🇬
                    #89
                    i buy this?
                    The most unreliable and problematic programmer possible, but it is also dirt cheap. A matter of luck, some units work, others (most of them ) are problematic.
                    • Gsa_rider67
                      • Apr 2023
                      • 5
                      • FRANCE
                      #90
                      I wouldn't have any use for it after having solved my problem, hence my economic choice.
                      What is the risk ?
                        VIP Moderator
                        • Aug 2018
                        • 4386
                        • Bulgaria 🇧🇬
                        #91
                        What is the risk ?
                        We are starting to get slightly off topic, you already have all the information you need, I don't think anything needs to be added.
                        • Gsa_rider67
                          • Apr 2023
                          • 5
                          • FRANCE
                          #92
                          i understand, I will come back with something concrete. thanks for the information.
                          • leham
                            • Oct 2015
                            can someone help, 1868 has password
                            thanks
                            • leham
                              • Oct 2015
                              added another dump incase first is bad
                              • peste
                                • 13436
                                • ROMANIA
                                #95
                                try..
                                • thatguycalledrob
                                  • Jan 2023
                                  • 7
                                  #96
                                  i buy this?
                                  Don't bother, I am also a n00b and got as far as finding the chip [2 hour teardown]. This unit won't clip on & you will need to de-solder and probably do something horrible to connect it up for the flashing procedure.
                                  I ended up removing the harddrive, cloning another laptop's OS onto it then plugging it back in. Not ideal, but will get the laptop up & running again (given that's all you want to do).
                                  • souaqi01
                                    • Dec 2015
                                    • 87
                                    • Maroc
                                    #97
                                    any help me plz Surface Laptop 3 Model 1868 locked
                                    • peste
                                      • 13436
                                      • ROMANIA
                                      #98
                                      try..
                                      • souaqi01
                                        • Dec 2015
                                        • 87
                                        • Maroc
                                        #99
                                        Originally posted by peste
                                        try..
                                        thans you very much but not work not remove password
                                          VIP Moderator
                                          • Aug 2018
                                          • 4386
                                          • Bulgaria 🇧🇬
                                          #100
                                            Microsoft Surface Laptop Surface Laptop 2 Notebook 2 Specification for Upgrade or Repair
                                            This specification for the Microsoft Surface Laptop Surface Laptop 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 2 boardview and Surface Laptop 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                            09-06-2024, 08:47 AM
                                            Microsoft Surface Laptop Surface Laptop 4 Notebook 4 Specification for Upgrade or Repair
                                            This specification for the Microsoft Surface Laptop Surface Laptop 4 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 4 boardview and Surface Laptop 4 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                            09-07-2024, 06:11 AM
