HP BIOS unlock tool
    Re: HP BIOS unlock tool
    Originally posted by lamo View Post
    hey, guys. have zbook studio g5. dumped ec bios chip. tool said, all is ok. password is still there. I patched second 256mbit chip. password still there. what should I do ?
    Search for your device thread or make your own, upload your both files and someone will help you.
    all donations are welcome,
      use RCUnlocker on the 16 mb bios..
        ok. here's 16mb dump from this zbook g5. can someone help me? rcunlocker don't work on this dump.
          Here's your Unlocked file, in the first boot go to bios menu and disable security options (Default).
          If the password still present upload your main bios, it could be 16MB or 32MB.
            and the password is still there. i've attached 32mb file to inspect.
              You should program the 2 Unlocked files together and follow the steps that I said before.
                I just want to thank you for all the info in this thread.
                I successfully removed the BIOS admin password on my HP Elitebook 840 G3 with HPUnlocker and a CH341A (with 3.3v mod) and NeoProgrammer v2.2.0.10 (and a heat gun).
                The Winbond 25Q128FVPQ was the chip to unlock.
                fyi, 'CH341A Programmer v1.30' could not read the chip properly, wheras NeoProgrammer worked perfectly.
                  works on elitebook 8730w.thanks!
                  I couldn't use the tools that Mazziff made.
                  https://mazzifsoftware.blogspot.com/...os-unlock.html
                    i did this procedure. now, when i'm trying to enter bios setup, i have a message "system locked".
                      You have used the both files together? Post an image for the message.
                        Hi,just tried to unlock my hp 840G5 Bios with thetool from the first page, but it doesn't worked. As there are two IC's which belongsto the BIOS, I'm not sure if I did it with the right one. So question first, is the large 32MB the right one and if yes, is somebody able to do the unlock of my attached one?
                          Here is the locked BIOS.
                            Post your request in the 840 G5 bios password thread - https://www.badcaps.net/forum/showthread.php?t=82478
                              ok. just managed to get to this unit. here's pic in attachment. I've flashed both chips: 16mb modified with the tool, and 32mb modified by you.
                                Hi! I have a 455 G7 clear of passwords but has remote verification i cannot get passed. Can you help me with it? I attach the two dumps, thanks!
                                  try this
                                    Originally posted by peste View Post
                                    try this
                                    unfortunately didn't work... the remote verification still pops up in installer
                                      I had a similar problem with a 435 g8 and hoaca888 did some magic with the dumps and finally it worked.
                                        try
                                          Originally posted by bbanana View Post
                                          try
                                          Same result, unfortunately... Asks for a specific mail in win 11 install... it's weird because in BIOS, there are no signs of security issues, Absolute persistence is inactive...
