HP OMEN 15-dc0850nd bios bricked
  • noos-x
    • Jan 2022
    • Morocco
    Hi
    I have a HP OMEN 15-dc0850nd that is stuck on black screen when turned on power button light up fan ruining and caps lock blinks 5 times(slow)+3 times(fast) according to HP website "This condition indicates the embedded controller cannot reach the BIOS within the established time limit."
    I'm going to flash the bios using an CH341A(waiting for it to arrive) and I have some questions
    There is two chip on the motherboard
    GigaDevice - 25B127DSIG I think this one has the bios since its a 16M size
    GigaDevice - 25Q80CSIG This one is 8M in size
    First question about the bios I downloaded the file from HP its sp127587.exe which create C:\SWSetup\sp127587\BIOS_Update.EXE
    Running the exe file give option to extract to usb or a directory both result in 2 files 084DA.sig(1 KB) and 084DA.bin(16,384 KB)
    Do i need to modify the bin file before flashing or just backup the one from the chip and flash?
    Second question is about the chip it seem most tools don't have this chip and clicking on detect will suggest 2 or 3 different chip
    From the research I did some people had success using W25Q128BV or GD25Q128C is it fine selecting a different chip suggested by the software?
    Last question what's the best tool/version to use AsProgrammer, CH341a Programmer..?
    PS: The bios on the laptop is the same attached below
  • hoaca388
    Badcaps
    • Jan 2022
    • 11717
    Re: HP OMEN 15-dc0850nd bios bricked
    084DA.bin is your bios file, no need to fix it. Dump your corrupted bios and compare with 084DA.bin file. Alway remember dump your bricked origin bios and save it before flash new bios.
    • JoWed
      Problems with reflashing BIOS Chip on omen by hp laptop 17 an104ng
      by JoWed
      Hello Community,
      I recently tried to change the Batterie on my Omen by HP Laptop 17 an104ng and after putting in the new batterie ([Batterie Link](https://www.amazon.de/7xinbox-17-AN0...&keywords=16%2...
      07-01-2025, 09:32 AM
      Common SPI bios chip programming Questions and Answers
      by SMDFlea
      Q: I have a bios request,i can`t post my backup as i can`t read from the chip.
      A: If you can`t read from it how do you expect to write to it ?.
      Q: Why is my bios chip unreadable ?.
      A: The programmer is faulty or has a worn or broken zif socket.
      The USB cable is frayed,connector pins worn or some other physical damage.
      Not enough amperage or voltage to power the programmer properly.
      Bad...
      09-02-2021, 04:40 PM
    • inck243
      Acer e15-e5-576g-5762 bricked. Bios chip won't interface in AsProgrammer.
      by inck243
      Thanks for any help. The board version is DAZAARMB6E0 REV: E. The bios chip is winbond 25Q64JVSIQ1736. W25Q64JV is not available in AsProgrammer -- only BV CV FV or FW_1.8c. The chip won't interface with asProgrammer and a CH341A. When I have this chip on the board, the laptop will not post but when I plug it in to power, the blue LED lights up, also the orange when the battery is connected. When I push the power on button, keyboard backlight turns on and the fan starts briefely then turns off. But I can't do anything to program this bios chip so I bought another one.
      The BIOS...
      07-25-2024, 09:17 AM
    • BMCappelletti
      Asus Chromebox CN62 - wrong chip put on BIOS reader
      by BMCappelletti
      Long story short:
      - dad converted Asus Chromebox CN62 into Windows compatible, with mrchromebox BIOS, years and years ago
      - gave the computer to his son a couple years later
      - son now decided to revert it to Chrome OS, to sell it as original (re-writing BIOS with the backup one created by his dad)
      - too lazy to remove the board from the case, thought a voltage regulator was the BIOS chip (you know... it has 8 legs)
      (seems like the story was not that short)
      He used alligator clips to read the chip. No luck reading it. Removed chip and placed on a SOC-8...
      01-08-2025, 07:27 PM
    • thxd43
      Lenovo laptop does not turn on, what does this number mean in a BIOS chip?
      by thxd43
      Hello, first of all, excuse me, I am using the translator, English is not my native language.
      I have a Lenovo ideapad 330S - 14IKB laptop.
      The tablet did not recognize me when I connected it, so I checked the device manager and I realized that there were many with the exclamation mark, so one by one I began to update their drivers until the sign disappeared of admiration, I even updated the BIOS, and the laptop rebooted normally and worked, so far so good, but the tablet still did not recognize me, I read on the internet that it could be due to a...
      02-23-2023, 08:37 PM
