2021 ROG Zephyrus M16 GU603HM
  • sikocan
    • Oct 2019
    • 344
    I need this BIOS extracted from the BIN. or EXE Fille:
    Device: Laptop
    Brand: ASUS
    Model: ASUS 2021 ROG Zephyrus M16 GU603HM
    Request : I need this BIOS extracted from the BIN. or EXE Fille
    Attached original dump, which is bricked. 16MB file.
    I've tried few things with hex editor didn't have much luck
    https://rog.asus.com/my/laptops/rog-.../helpdesk_bios
  • amirheidari681
    • Oct 2021
    • 43
    • iran
    HI. I need complete bios of this laptop
    model : asus ROG Zephyrus M16 gu603hm
    sn: m7nrkd00654329d
    mb part : GX703HS r 3.0
    the keyboard doesn't work suddenly
    replace new keyboard but not work and check io to k.b jack. it was ok​.
    • peste
      • 13176
      • ROMANIA
      sn: m7nrkd00654329d
      post the original bios of the laptop even if it is corrupted..
      • tanveerah2005@yahoo.com
        • Jun 2020
        • 7
        • pakistan
        hi please clear this bios thanks !
        GU603HM-211.ZM16
        SN: M6NRKD008291225
        CN: 1Z46​
          SMDFlea commented
          Editing a comment
          Post moved to HM thread from HE ...
      • guar33
        • Dec 2017
        • 5
        • Украина
        It's not your BIOS or it's badly damaged.
        here is the bios from the engineers​
          • Jun 2020
          • 7
          • pakistan
          thank you so so so much its working
          • fredo
            • Aug 2016
            • 81
            • syria
            Please rebuild the BIOS. The device is working perfectly, but the external graphics card is not recognized in Windows.
            Model GU603HM
            GX703HS rev 3.0
            S n : M6nrkd00902022b
              SMDFlea commented
              Editing a comment
              Thread merged.
          • hoaca388
            Badcaps
            • Jan 2022
            • 12085
            Model GU603HM
            GX703HS rev 3.0
            It's not a bios problem.
            • digitaldisorder
              digitaldisorder
              • Jun 2022
              • 18
              Original bios was damaged and unable to be read. I was able to download, and flash downloaded BIOS (Version 317​) from ASUS with CH341A programmer to a new chip (old was Micronix MXIC MX 77l12850f, new same chip, not Winbond) but serial number is missing, and not sure which section needs to be replaced. Can someone upload a working BIOS? I have uploaded the BIOS that was flashed to the current chip. Everything is working as expected but certain functionality on the laptop does not work without the serial number (M5NRKD023462215).
              • peste
                peste commented
                Editing a comment
                post merged..
              • 21433
              Originally posted by digitaldisorder
              Original bios was damaged and unable to be read. I was able to download, and flash downloaded BIOS (Version 317) from ASUS with CH341A programmer to a new chip (old was Micronix MXIC MX 77l12850f, new same chip, not Winbond) but serial number is missing, and not sure which section needs to be replaced. Can someone upload a working BIOS? I have uploaded the BIOS that was flashed to the current chip. Everything is working as expected but certain functionality on the laptop does not work without the serial number (M5NRKD023462215).
              bios + DMI. The DMI is from a different bios in this thread. The serial number has been changed to yours.
              • digitaldisorder
                digitaldisorder
                • Jun 2022
                • 18
                Much appreciated. I will update will results after flashing. Thank you!
                • digitaldisorder
                  digitaldisorder
                  • Jun 2022
                  • 18
                  so far so good! thanks again!
                    SMDFlea commented
                    Editing a comment
                    You`re welcome :-)
                • dukaan alaaql
                  • Jun 2025
                  • 8
                  Keyboard Stopped working or even responding
                    • 21433
                    What do you want ?
                    • dukaan alaaql
                      • Jun 2025
                      • 8
                      I have a problem with the same kind
                      Device: Laptop
                      Brand: ASUS
                      SN:M5NRKD023462215
                      CN:KKRY
                      MFD:2021-05
                      I managed to Flash digitaldisorder ​ merged bios bin that the professionals provided
                      Everything works Fine except for the Keyboard , the touchpad is working only in UEFI and I am able to write EZ Flash Files .Bin
                      usb boots fine when its 2.0 drive , usb3 is not working
                      Really appreciate if I can reach the keyboard to work again
                      • dukaan alaaql
                        • Jun 2025
                        • 8
                        Before I try to flash
                        The old chip was showing error while I am reading and I was able to dump this
                          • 21433
                          You made a mistake backing up as it`s only 1MB ,the auto-detect is very poor with some programmers if it`s a chip that isn`t supported. The USB3 not working is morel ikely to be a hardware problem.
                          • dukaan alaaql
                            • Jun 2025
                            • 8
                            I was wondering if I flashed the EC chip with a newer file extracted from ASUS bios files will fix the hardware issues , I backed them up anyway ,
                            • dukaan alaaql
                              • Jun 2025
                              • 8
                              something weird happened : I did 2 tests from bios dump and EZ extracted EC firmware file and nothing changed , Wiped the EC Chip with FF FF FF FF and restored a 317 EZ Flash bios the EC firmware changed by UEFI readings but the chip is now Empty with FF FF FF FF
                              I will try to flash with the dumped file and test it out .
                              • hoaca388
                                Badcaps
                                • Jan 2022
                                • 12085
                                This is Nvidia fimware.
                                  ASUS ROG GU604VY-NM001XK Notebook Zephyrus M16 Specification for Upgrade or Repair
                                  This specification for the ASUS ROG GU604VY-NM001XK Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GU604VY-NM001XK boardview and GU604VY-NM001XK schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                  09-07-2024, 07:20 AM
                                  ASUS ROG GU604VI-NM049W Notebook Zephyrus M16 Specification for Upgrade or Repair
                                  This specification for the ASUS ROG GU604VI-NM049W Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GU604VI-NM049W boardview and GU604VI-NM049W schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                  ASUS ROG GU603 Notebook Zephyrus G16 Specification for Upgrade or Repair
                                  This specification for the ASUS ROG GU603 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GU603 boardview and GU603 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for ASUS ROG GU603 Notebook...
                                  ASUS ROG GU603VI-N4020W Notebook Zephyrus G16 Specification for Upgrade or Repair
                                  This specification for the ASUS ROG GU603VI-N4020W Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GU603VI-N4020W boardview and GU603VI-N4020W schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                  09-07-2024, 07:19 AM
                                  ASUS ROG GU603ZM-K8058WS Notebook Zephyrus M16 Specification for Upgrade or Repair
                                  This specification for the ASUS ROG GU603ZM-K8058WS Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GU603ZM-K8058WS boardview and GU603ZM-K8058WS schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
