Dell XPS 15 9575 2-in-1 LA-F211P rev 1.0
  • hoaca388
    Badcaps
    • Jan 2022
    • 12440
    Re: Dell XPS 15 9575 2-in-1 LA-F211P rev 1.0
    Originally posted by reformatt
    Got a Dell XPS 15 9575 (LA-F211P) brought in that apparently died after a BIOS update. Unit is pretty lifeless, although the rails etc all look to be up, so yeh, looks like corrupted BIOS.
    I've taken the BIOS chip off and dumped it, which I've attached here. Perhaps the guru's here could cast their eye over it overnight? Not sure how to rebuild it just yet with Dell's recovery BIOS.
    I haven't tried any of the donors here just yet, as it's a PITA pulling out and putting this board back in.
    S/Tag is 8TCK5Q2, E/Code is 19188873722.
    • reformatt
      • Feb 2020
      • 1549
      Still no life. I did do some buzzing around on the board, and found what I think is the 2nd MOSFET shorted (don't have a schematic but its PQ113). I did replace but still lifeless. My assumption is that this FET failed during the customers update. Apparently they had some battery issue and were on phone to Dell (and they asked to update the damn thing which is when it failed).
      It has a MEC5105 EC in it, and judging by it's behaviour I think the original BIOS is ok, but the EC needs to be reprogrammed. Can't find any info on it on whether it needs programming or not.
      • reformatt
        • Feb 2020
        • 1549
        Ok it's working with this BIOS https://www.badcaps.net/forum/showpo...37&postcount=9
        However, when I go to update it from Dell's most recent update, it starts updating the EC code of the BIOS, and shuts down around 77% of the way through. Don't know if this is a bug in the update, or a crook EEPROM. Will try Dell's earlier BIOS updates.
        UEFI tool does show the EC region so the MEC gets it from the main BIOS chip and doesn't need seperate programming.
        • reformatt
          • Feb 2020
          • 1549
          So the donor BIOS was V1.7.1 with EC V1.0.36. The V1.20 update has EC V1.0.42. This is in region 1700000h - 1750000h.
          So I tried an earlier version V1.14 and that went through ok. I also noticed that there are 2 USB PD controllers flashed in the process. When the donor BIOS was originally tried, the WIFI adaptor was not present and USB devices weren't working on the daughter board on the RHS. After a successful flash, that's all working again. Tried up to V1.19 and went ok.
          Seems the V1.20 BIOS update from Dell has a bug. But I've spent way too long on this now to test it out. So just avoid it for now. BTW, the BIOS will alert you that there is no service tag present, and will allow you to set it via BIOS setup.
          And this all started with user contacting Dell about a battery issue - presumably PQ113 being shorted I guess. Far out.
          • TheAdamSVK
            • Nov 2022
            • 5
            • Slovakia
            Hi, I see you have also an XPS 15 9575, I would like to ask for a favour if possible. Im asking whomever that owns a working XPS 15 9575 as that is my only choice except a motherboard replacement which is expensive "solution".* Could you please send me per email or somewhere on Dropbox a dump image of you BIOS ?*
            I received a forced BIOS update and after that is my XPS with No Post / No power altho the motherboard itself has power/electricity so it's not dead (tested via electrical engineering tools). I just need a ROM file / Bios dump file from a working XPS 15 9575 so I can hard flash it onto my XPS a make it run again. Otherwise I have also a dead 2000$ machine on the table.*
            The easies and safest way to create a bios dump file is via this software (tested)
            majorgeeks.com/mg/getmirror/universal_bios_backup_toolkit,1.html
            Many thanks for help in advance !*
              • 22275
              Originally posted by TheAdamSVK
              The easies and safest way to create a bios dump file is via this software (tested) majorgeeks.com/mg/getmirror/universal_bios_backup_toolkit,1.html
              That software will not make a full backup,for that you need to use an SPI programmer.You can post your backup to badcaps then in a zip or rar archive and someone will help.
              BIOS guides, methods, resources and tools - https://www.badcaps.net/forum/showthread.php?t=103526
              1. How to dump and flash - https://www.badcaps.net/forum/showpo...40&postcount=2
              • TheAdamSVK
                • Nov 2022
                • 5
                • Slovakia
                #27
                Thanks for feedback.
                As I mentioned I need the Bios dump from someone who has a working XPS 15 9575. Mine is simply not working. I need the dump file so I can hard flash it directly on my bios chip via the SPI programmer. Or do you know a way how to extract a ROM file from the Bios.exe file on Dell Product Support page ? Because the .exe file has approx 19MB size so it looks like it's compressed as the BIOS ROM file should be about 32MB in size.
                  • 22275
                  Yes - https://www.badcaps.net/forum/showpo...5&postcount=12
                  Yes,as verified by @reformatt at post #23 - https://www.badcaps.net/forum/showpo...37&postcount=9
                  • hoaca388
                    Badcaps
                    • Jan 2022
                    • 12440
                    #29
                    If you already have a spi programmer, why don't you backup the error bios file and post it here. The file extracted from *.exe is incomplete.
                    • TheAdamSVK
                      • Nov 2022
                      • 5
                      • Slovakia
                      #30
                      This is the BIOS file that was on my XPS 9575 when it died.
                      • hoaca388
                        Badcaps
                        • Jan 2022
                        • 12440
                        #31
                        New file
                        • TheAdamSVK
                          • Nov 2022
                          • 5
                          • Slovakia
                          #32
                          Originally posted by hoaca388
                          New file
                          What is that exactly ? I see a bios file but what's the change in the file ? Could you pls elaborate?
                          #Thx4Help
                          • hoaca388
                            Badcaps
                            • Jan 2022
                            • 12440
                            #33
                            #Thx4Help
                            Change most regions except the descriptor region.
                            • TheAdamSVK
                              • Nov 2022
                              • 5
                              • Slovakia
                              #34
                              Hi, thanks again for the help, tried the BIOS file you've posted me here. It didn't work.
                              I'm gonna try explain from scratch the background story completely. Thing is, I do not recall if I tried undervolt the computer when it was working or not, nor do I remember when BIOS version was on. All I remember is that there was some BIOS update pending but I didn't wanted to do that cuz I know with a new update comes new issues. BUT thus comes the theory. What if the device has been undervolted, and there was some old bios version that still allowed undervolting and when the forced bios update was trying to get through, it was the newer version that blocked the undervolting thus didn't finished successfully causing the system get blocked. That could mean that some firmware could have one version and the other ME a different version = causing conflict during system start. What would be the solution for this? Simply try to flash an old BIOS version that allows the undervolting?
                              Thanks in advance for consultation.
                              The system is already dead for lo ger than a half year 😭
                              • hoaca388
                                Badcaps
                                • Jan 2022
                                • 12440
                                #35
                                Ok, try 1.5.1 version
                                  DELL XPS 9575 Hybrid (2-in-1) 15 Specification for Upgrade or Repair
                                  This specification for the DELL XPS 9575 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 9575 boardview and 9575 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL XPS 9575 Hybrid...
                                  09-06-2024, 04:40 PM
                                  09-06-2024, 12:18 PM
