need bios dump dell latitude 5420 (cpu 11th)
    with post 800
    laptop on / off few times than led showing only color
    white red blue than auto off , pls someone help me thanks
      need repair this bios no power
        Read https://www.badcaps.net/forum/troubl...ore-posting and post the service tag.
          ok thanks
              Hi, a question...
              Bios for this model (5420) and for this mobo (LA-K491P) is unique for each service tag?
              I tried with several bios of this thread but any is working, that is the reason for the question.
                Unfortunately The service tag erased from bottom Case and when i tryed another bin it working power but no data just three colors on screen
                  try
                  Service Tag: 8LGY2F3
                    Originally posted by danito View Post
                    try
                    thanks
                    i tryed this file it work power just for second then turn off again.
                    i well appreciate for any one can help
                      pls i need the clear me file for dell latirude 5420
                      ST F7VGSQ3
                        ST F7VGSQ3
                        Latitude 5420
                        Service Tag: F7VGSQ3
                        Become a Badcaps supporter
                        Thanks to all supporters.
                          Thanks man
                          work like magic
                            HELP HELP
                            I have a CH341 programmer, but it is not listed when I search for my BIOS chip. Then, I tried to use detect with no results. I manually searched XMC XM25RH128CHIN chip doesn't appear in the list. I used CH341 2.2 version/ NEO Prog and AS programmer, but non of the programmers has this chip in the listing
                              Originally posted by Unique1234 View Post
                              HELP HELP
                              AsProgrammer v2.1.2 supports it. https://github.com/nofeletru/UsbAsp-flash/releases
                                HELP HELP
                                Thank you for the reply
                                I downloaded the app ASProgramme 2.1.2, and as per your Picture attachment,t I can see the chip in the listing, but the software ASProgramme won't recognise it. My CH341(black), so it won't work, but I know that the programmer CH341 does work fine
                                Advice from the expert will be much appreciated.
                                  HELP HELP
                                  Are you using an adapter board or a clip.
                                    I took out the bios chip and mounted it on the board In the SOP board, I can read all CH341, NEO prog, but won't recognise it in AS PROG 2.1.2
                                      Please bios for LA-K491p Rev. 2.0 A01 2021-04-28
                                      ST 1JKMPN3
                                      Core i5 11th Gen
                                      Laptop power led turns on for 15 seconds, lights on keyboard, and turn off, a cycle.
                                      Attached bios backup
