need bios dump dell latitude 5420 (cpu 11th)
  • Murtaza527
    • May 2018
    • 262
    • Malaysia
    #801
    with post 800
    laptop on / off few times than led showing only color
    white red blue than auto off , pls someone help me thanks
    • m.maher
      • 32
      • egypt
      #802
      need repair this bios no power
        • 22135
        Read https://www.badcaps.net/forum/troubl...ore-posting​ and post the service tag.
        • m.maher
          • 32
          • egypt
          #804
          ok thanks
          • ruletero
            • Nov 2018
            • 183
            • Mexico
            #805
            • ruletero
              • Nov 2018
              • 183
              • Mexico
              #806
              Hi, a question...
              Bios for this model (5420) and for this mobo (LA-K491P) is unique for each service tag?
              I tried with several bios of this thread but any is working, that is the reason for the question.
              • m.maher
                • 32
                • egypt
                #807
                Unfortunately The service tag erased from bottom Case and when i tryed another bin it working power but no data just three colors on screen
                • danito
                  • Jun 2016
                  • 1190
                  #808
                  try
                  Service Tag: 8LGY2F3​
                  • m.maher
                    • 32
                    • egypt
                    #809
                    Originally posted by danito
                    try
                    thanks
                    i tryed this file it work power just for second then turn off again.
                    i well appreciate for any one can help
                    • Kiki Cares
                      • Feb 2022
                      • 29
                      • Nigeria
                      #810
                      pls i need the clear me file for dell latirude 5420
                      ST F7VGSQ3
                      • hoaca388
                        Badcaps
                        • Jan 2022
                        • 12421
                        #811
                        ST F7VGSQ3
                        Latitude 5420
                        Service Tag: F7VGSQ3​
                        • Kiki Cares
                          • Feb 2022
                          • 29
                          • Nigeria
                          #812
                          Thanks man
                          work like magic
                          • Unique1234
                            • Sep 2019
                            • 16
                            • Wisely
                            #813
                            HELP HELP
                            I have a CH341 programmer, but it is not listed when I search for my BIOS chip. Then, I tried to use detect with no results. I manually searched XMC XM25RH128CHIN chip doesn't appear in the list. I used CH341 2.2 version/ NEO Prog and AS programmer, but non of the programmers has this chip in the listing
                              • 22135
                              Originally posted by Unique1234
                              HELP HELP
                              AsProgrammer v2.1.2 supports it. https://github.com/nofeletru/UsbAsp-flash/releases
                              • Unique1234
                                • Sep 2019
                                • 16
                                • Wisely
                                #815
                                Originally posted by Unique1234 View Post
                                HELP HELP
                                I have a CH341 programmer, but it is not listed when I search for my BIOS chip. Then, I tried to use detect with no results. I manually searched XMC XM25RH128CHIN chip doesn't appear in the list. I used CH341 2.2 version/ NEO Prog and AS programmer, but non of the programmers has this chip in the listing​
                                Thank you for the reply
                                I downloaded the app ASProgramme 2.1.2, and as per your Picture attachment,t I can see the chip in the listing, but the software ASProgramme won't recognise it. My CH341(black), so it won't work, but I know that the programmer CH341 does work fine
                                Advice from the expert will be much appreciated.
                                  • 22135
                                  HELP HELP
                                  Are you using an adapter board or a clip.
                                  • Unique1234
                                    • Sep 2019
                                    • 16
                                    • Wisely
                                    #817
                                    I took out the bios chip and mounted it on the board In the SOP board, I can read all CH341, NEO prog, but won't recognise it in AS PROG 2.1.2
                                    • ruletero
                                      • Nov 2018
                                      • 183
                                      • Mexico
                                      #818
                                      Please bios for LA-K491p Rev. 2.0 A01 2021-04-28
                                      ST 1JKMPN3
                                      Core i5 11th Gen
                                      Laptop power led turns on for 15 seconds, lights on keyboard, and turn off, a cycle.
                                      Attached bios backup
                                      • Edgar Velasco
                                        • 16
                                        • MEXICO
                                        #819
                                        I need help to remove the password please dell latitude 5420
                                        GDF40 LA-K491P REV:2
                                        service tag 44RN6D3
                                        EX 8995425015
                                        • hoaca388
                                          Badcaps
                                          • Jan 2022
                                          • 12421
                                          #820
                                          service tag 44RN6D3
                                          EX 8995425015
                                          Unkocked
                                          • mirjana
                                            EC dump request – Dell Latitude 5420, GDF40 LA-K491P Rev 3.0, MEC5107-LJ
                                            by mirjana
                                            I need the EC firmware dump for Dell Latitude 5420, motherboard GDF40 LA-K491P Rev 3.0 (A02).
                                            The embedded controller is MEC5107-LJ (UE1).
                                            The EC flash chip is W25Q80DV, 8Mbit (1MB).
                                            I already have the 32MB BIOS dump (W25Q256JV), but my system is still not powering on — just amber blink. I suspect the EC firmware is missing or corrupted.
                                            If anyone has this board and can share their EC dump from the 25Q80DV, I’d be very grateful.
                                            Thank you in advance!...
                                            07-16-2025, 12:55 AM
                                            DELL Latitude 5420 Notebook Rugged Specification for Upgrade or Repair
                                            This specification for the DELL Latitude 5420 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5420 boardview and 5420 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 5420...
                                            09-06-2024, 03:21 PM
                                            DELL Latitude 5420 Notebook 5000 Specification for Upgrade or Repair
                                            09-06-2024, 09:23 AM
                                            09-06-2024, 08:47 AM
