help need bios file hp pavilion 15-cs2081TX
  • vienzen
    • Feb 2015
    • 112
    • PHILIPPINES
    DAG7BMB48C0 REV:C
    problem no power
    note: l'm the second tech to repair this laptop I don't know if the bios backup is the original
    bios backup file
    • 21209
    Re: help need bios file hp pavilion 15-cs2081TX
    Bios + DMI attached.
    The bios download is here from the 15-cs2081TX support page: https://ftp.hp.com/pub/softpaq/sp135...0/sp135625.exe .When you run the exe it gives you the option to save a copy of the new bios.In this exe there are 2 bios for different models, 1 is only 8MB the other is 16MB. The 16MB one is naned 084C0.bin .If you search through your backup with a hex editor using the text search for 084C0 youll see its the same bios . Do a text search again for the serial number,you`ll see the start of the DMI block and then you can decide what offsets to use and copy the DMI from your backup to the virgin bios. The DMI block offset to copy is
    420000 - 424FFF
    • vienzen
      • Feb 2015
      • 112
      • PHILIPPINES
      420000 - 424FFF
      Thank you
      • microlab
        • Nov 2015
        • 12
        • italy
        420000 - 424FFF
        • roma19
          • Apr 2017
          • ukraine
          Thank you
          • Citymin
            by Citymin
            S/N : 5RNK9FFT70...
            08-05-2025, 05:12 AM
          • iZakre
            HP Pavilion 15 bc400ns - Complete Black Screen - Only video on live usb
            by iZakre
            Hello everybody!
            To put you in context I recently replaced the battery from my HP Pavilion 15 bc400ns with a used one, everything was going good. The same day, I decided to update the BIOS, everything went good. The thing occurred after I let the battery drain iddling on Windows 11 for the second time to calibrate it that the screen did not turn on again, the computer was on but the screen did not turn, like it would not wake from hibernation. I decided to restart the computer but got no video.
            The thing is that I had installed TeamViewer and could log into the computer...
            02-19-2023, 02:27 PM
          • ianhaney
            HP Pavilion DV2130ea bios bin file request
            by ianhaney
            I am new to the forum and looking for a HP Pavilion DV2130ea bios bin file. I can't seem to find one online, I can only find a exe file
            02-16-2025, 08:14 AM
          • Forest79
            by Forest79
            07-23-2023, 07:39 AM
          • black0hackers
            Need backup bios file X1 carbon Gen 10 nm-d961 rev 2.0
            by black0hackers
            my bios ic is die. so i want backup file to make bios
            some one have can give me. thank you all
            jyg70/jx4c0
            03-23-2023, 03:34 AM
