RCUnlocker
  • yok60521
    • Apr 2024
    • Taiwan
    #1261
    Originally posted by robkom
    Thank you for the help that wasn't there - my laziness caused this inquiry, because of course after looking through the forum threads, I found the answer to my earlier request for help.
    Hey, how did you unlock it?
    I'm getting the same "Wrong chip. Try reading and unlocking 16MB chip" message too.
    Thanks a lot!
    • T3K1L4NG
      • Jan 2022
      • 7
      • philippines
      #1262
      Good day sir Please Help me
      HP ellite book 840 G3 bios Administrator password
      proid 1HL7OUP#ABL
      SN# 5CG7064XLS
      motherboard 6050A2892401-MB-A01
        • 20855
        proid 1HL7OUP#ABL
        SN# 5CG7064XLS
        You havn`t said if you have tried RCUnlocker or not. If you have it will fail as you selected the wrong type of chip to backup, you chose OTP (one time programmable) and it is not one of those. By choosing OTP it adds extra code to the backup, it should be 16,384KB but yours is 16,385KB, 1KB extra. Make another backup and don`t choose the OTP chip or delete the extra code with a hex editor, then try RCUnlocker again. If that doesn`t work use the older HP Unlocker software
        • elmasryomda
          • Aug 2016
          • 15
          • egypt
          #1264
          The RCUnlocker is not working and gives this message. Please help.
          • peste
            • 12778
            • ROMANIA
            #1265
            post S/N, full name and model, motherboard model, product number,etc.
            post the original contents of the bios chip..
            • elmasryomda
              • Aug 2016
              • 15
              • egypt
              #1266
              HP ProBook 640 G5 6050a2930101
              i have 2 lap same this model - password
              I have another version of HPUnlocker, but after removing the laptop password, it works, but a message appears
              there is aprblem with the hp endpoint security controller problem
              Is the issue (HPUnlocker) the reason for the message appearing?
              Thank you, brother
            • elmasryomda
              • Aug 2016
              • 15
              • egypt
              #1267
              I need a video to explain because I don't understand the method
                • 20855
                I don`t have time to make a video . Here`s your main bios..
                • elmasryomda
                  • Aug 2016
                  • 15
                  • egypt
                  #1269
                  Thank you very much, SMDFlea , for your help.
                  I read the topic more than once, and after several attempts, I was able to repair the BIOS file and remove the endpoint message.
                  However, another message appeared ( Manufacture Programming Mode in Unlock mode).
                  I used a program (BCU BIOS Configuration Utility)and made a copy of the file(config) from another laptop of the same model, and it worked fine.
                  But the question here is:
                  The device data label was previously removed.
                  So how can I obtain laptop data, such as the serial number, model, etc.?​
                  • robkom
                    • Jul 2022
                    • 19
                    • Poland
                    #1270
                    Thanks a lot!
                    There are two bios chips on the motherboard - one, the correct one is underneath. You have to unscrew the motherboard and underneath there is 16 MB of bios. And that is the correct one.
                    RCunlocker easily removed the password from it and everything is ok.
                      HP Clean VSS2 dumps,fix Endpoint Security error
                      by SMDFlea
                      Just a thread to post clean VSS2 files/dumps in.A clean VSS2 file can, in some cases, fix
                      the infamous **"Endpoint Security" error message.
                      Be aware that if you use a clean VSS2 you may need to fill in missing DMI info using HP BCU !
                      I`ve included some clean files/dumps,offsets and a few scripts to autopatch a few models.
                      The offsets and file sizes are part of the naming convention i`ve used for the extracted
                      files.
                      hoaca388 has made an excellent guide how to extract the VSS2 file and edit/clean it up by
                      filling everything after...
                      08-08-2024, 03:14 PM
                      HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook 400 Specification for Upgrade or Repair
                      This specification for the HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the HP ProBook 450 15.6 inch G10 Notebook PC boardview and HP ProBook 450 15.6 inch G10 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                      09-07-2024, 07:12 AM
                      09-07-2024, 06:40 AM
                      HP ProBook ProBook Fortis 14 inch G9 Notebook PC Notebook Specification for Upgrade or Repair
                      This specification for the HP ProBook ProBook Fortis 14 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ProBook Fortis 14 inch G9 Notebook PC boardview and ProBook Fortis 14 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
                      09-07-2024, 05:50 AM
