RCUnlocker
Good day sir Please Help me
HP ellite book 840 G3 bios Administrator password
proid 1HL7OUP#ABL
SN# 5CG7064XLS
motherboard 6050A2892401-MB-A01
Attached FilesPremium supporters get full download access and other benefits.
You havn`t said if you have tried RCUnlocker or not. If you have it will fail as you selected the wrong type of chip to backup, you chose OTP (one time programmable) and it is not one of those. By choosing OTP it adds extra code to the backup, it should be 16,384KB but yours is 16,385KB, 1KB extra. Make another backup and don`t choose the OTP chip or delete the extra code with a hex editor, then try RCUnlocker again. If that doesn`t work use the older HP Unlocker softwareComment
If you have found our forum useful please consider supporting us. Subscribe for a small monthly fee and receive extra benefits including our boardview / schematic archive.
It only takes 1 minute:
https://www.badcaps.net/settings/subscriptionsComment
HP ProBook 640 G5 6050a2930101
i have 2 lap same this model - password
I have another version of HPUnlocker, but after removing the laptop password, it works, but a message appears
there is aprblem with the hp endpoint security controller problem
Is the issue (HPUnlocker) the reason for the message appearing?
Thank you, brotherAttached FilesPremium supporters get full download access and other benefits.
I don`t have time to make a video . Here`s your main bios..Attached FilesPremium supporters get full download access and other benefits.
Thank you very much, SMDFlea , for your help.
I read the topic more than once, and after several attempts, I was able to repair the BIOS file and remove the endpoint message.
However, another message appeared ( Manufacture Programming Mode in Unlock mode).
I used a program (BCU BIOS Configuration Utility)and made a copy of the file(config) from another laptop of the same model, and it worked fine.
But the question here is:
The device data label was previously removed.
So how can I obtain laptop data, such as the serial number, model, etc.?Comment
There are two bios chips on the motherboard - one, the correct one is underneath. You have to unscrew the motherboard and underneath there is 16 MB of bios. And that is the correct one.
RCunlocker easily removed the password from it and everything is ok.Comment
Dont't undestand how to use it !
I downloaded RCUnlocker, but when trying to launch, there is these message : Missing file destination argument!
Can you help me ?Comment
I tried but it did not work, can someone help me
Model: HP ELITEBOOK 840 G5
MB: 6050a2945601-mb-a01
s/n: 5cg90960qjAttached FilesPremium supporters get full download access and other benefits.
Please help! hp probook 450 g3 bios administrator password reset, please!This is a multitool and unlocker for several series of laptops. Works on Windows. No python etc installing needed, all included in package. Everything is tested by myself but since every laptop is not made equally, there might be edge cases. Always VERIFY your file after reading!!!
Unlocking
HP - ProBook, EliteBook, ZBook (including 32MB models)
Chromebooks from all various manufacturers
Apple - everything older than T2
More to come...
Information display (helps to verify file integrity)
HP - ProBook, EliteBook, ZBook (up to 16MB models for now)
Custom logo removal
Usage: Drag and drop .bin file to .exe file.
In case there are problems with unlocking your laptop, write a short description of the issue, upload original file and if possible, _unlocked.bin file aswell. Just crying for help is useless. Keep the topic as clean as possible.
You may ask for feature requests, I'll see what I can do.
thanks in advance!Comment
Hello, I tried using RCUnlocker from post #1. I modified the backup .bin of the Winbond 16MB chip, then wrote the generated unlock.bin back to the Winbond 16MB chip.
However, the BIOS password still appears. Please also help me unlock the password of the laptop.
Thank you very much.
NB HP ProBook 430 G7
ProdID: 6YX16AV
S/N: 5CD0013S38
mainboard model: DAOX8ITB8D0
Rev.DAttached FilesPremium supporters get full download access and other benefits.
try..Hello, I tried using RCUnlocker from post #1. I modified the backup .bin of the Winbond 16MB chip, then wrote the generated unlock.bin back to the Winbond 16MB chip.
ProdID: 6YX16AV
S/N: 5CD0013S38
by SMDFleaJust a thread to post clean VSS2 files/dumps in.A clean VSS2 file can, in some cases, fix
the infamous **"Endpoint Security" error message.
Be aware that if you use a clean VSS2 you may need to fill in missing DMI info using HP BCU !
I`ve included some clean files/dumps,offsets and a few scripts to autopatch a few models.
The offsets and file sizes are part of the naming convention i`ve used for the extracted
files.
hoaca388 has made an excellent guide how to extract the VSS2 file and edit/clean it up by
filling everything after...-
Channel: BIOS Requests ONLY!
HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook 400 Specification for Upgrade or RepairThis specification for the HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the HP ProBook 450 15.6 inch G10 Notebook PC boardview and HP ProBook 450 15.6 inch G10 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...09-07-2024, 07:12 AM
HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook 400 Specification for Upgrade or RepairThis specification for the HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the HP ProBook 450 15.6 inch G10 Notebook PC boardview and HP ProBook 450 15.6 inch G10 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...09-07-2024, 06:40 AM
This specification for the HP ProBook ProBook Fortis 14 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ProBook Fortis 14 inch G9 Notebook PC boardview and ProBook Fortis 14 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...09-07-2024, 05:50 AM
- Loading...
